Anyone ever experienced an ilogic event not firing. Im testing with a rule that has only one line of code and that is Logger.Debug("Test"). If I run the rule manually I can see everything just fine. If I take the same rule and add it to whatever event its never firing.
I tried multiple events like on new document, on before save etc. . I also tried with messagebox to make sure I dont miss anything. The same thing works fine on another workstation. We are using Inventor 2023.1.1.
Solved by tobias_wiesendanger. Go to Solution.
Found it. Under security settings all events where deactivated...
