iLogic equation answers in radians. I need degrees. (Probably a Noob question)
I'm trying to do a simple Trig equation in iLogic, but it's returning the value in radians even though the parameter is set to Degrees. (Please see attached)
Is there something I need to add to my code to make it return an answer in degrees.
Thanks in advance.
GavoGarmo
Public Function RToD(passnum As Double) As Double
    Return passnum * (180 / PI)
End Function
Public Function DToR(passnum As Double) As Double
    Return  passnum * (PI / 180)
End Function
Thanks for the fast reply, but how does that code fit around my existing iLogic code?
I've tried it in a few differnt positions but it's just spitting up errors.
see if this helps...
Sub Main
	Dim dNumber As Double = 45
	MsgBox(dNumber & " Deg")
	Dim dNumber1 as Double = DToR(dNumber)
	MsgBox(dNumber1 & " Rad")
	Dim dNumber2 as Double = RToD(dNumber1)
	MsgBox(dNumber2 & " Deg")
End Sub
End Function
End Function
if that did not help try this..
	Dim dNumber1 as Double = dNumber * (PI / 180) 'Deg to Rad
	Dim dNumber2 as Double = dNumber1 * (180 / PI) 'Rad to Deg
or try this..
t1 = (SpecialBevelDim1 / SpecialBevelDim2)
i1 = Atan(t1) * (180 / PI) 'Rad to Deg
t1 = (SpecialBevelDim2 / SpecialBevelDim1)
i2 = Atan(t2) * (180 / PI) 'Rad to Deg
I'd put in a mathmatical solution earlier in the day, but it seemed like a bit of a fudge through, so was hoping there was a way to just flip the units from one to the other.
The VB stuff is still a bit of a mystery to me at the moment, so I think the mathmatical solution is probably best for people at my level of programming.
Thanks again for your help.
