Is there any way of programming this:
![zoebakerbushby_0-1721898086180.png zoebakerbushby_0-1721898086180.png](https://forums.autodesk.com/t5/image/serverpage/image-id/1390855i3A1003912BF552EB/image-size/medium?v=v2&px=400)
Where there is the extension line and the leader (arrow line) is positioned from this?
Currently all I can get is this:
![zoebakerbushby_1-1721898142405.png zoebakerbushby_1-1721898142405.png](https://forums.autodesk.com/t5/image/serverpage/image-id/1390856iB9F2A863F84A9F99/image-size/medium?v=v2&px=400)
Dim asmDoc As AssemblyDocument = oView.ReferencedDocumentDescriptor.ReferencedDocument 'Reference the assembly document
Dim PVSWP As WorkPlane = asmDoc.ComponentDefinition.WorkPlanes.Item("VERTICAL STS ROTATION")
PVSCL = oSheet.Centerlines.AddByWorkFeature(PVSWP, oView)
xValue = PVSCL.EndPoint.X * 10
yValue = PVSCL.EndPoint.Y * 10
Dim leaderNotes = TANK_PLAN_1.DrawingNotes.LeaderNotes
Dim leaderNote1 = leaderNotes.Add("Diamond Knurl Note 1",ThisDrawing.Geometry.Point2dList({{xValue + 10, yValue + 10}, {xValue, yValue+10}}),PLAN_VIEW.GetIntent("TEST"), "PRIMARY VERTICAL PLATE BOLT SEAM")
