Hello All
im having some strange issues with ilogic drawings.
im trying to migrate and update a heap of old drawings to our new title blocks and drawing standard and style so we can put them into vault.
ive pretty much got everything running with replacing standard, titleblock, border, dimensions and notes.
however I cannot get bend notes or bend tags to update to the new standard's default layer and corresponding default style. ive tried them as drawing notes, general notes, leader notes, drawing dimensions and general dimensions and i cannot get them to change to the new standard default layer.
also about to undertake each view linetype so if you have any pointers with that would also be appreciated.
here is a snippet of relevant sections in question.
Dim oDoc As DrawingDocument
oDoc = ThisApplication.ActiveEditDocument
Dim oSheet As Sheet
oSheet = oDoc.ActiveSheet
'iterate through sheets
For Each oSheet In oDoc.Sheets
oSheet.Activate
Dim oActObjDef As ObjectDefaultsStyle
oActObjDef = oDoc.StylesManager.ActiveStandardStyle.ActiveObjectDefaults
Dim oLNote As LeaderNote
For Each oLNote In oSheet.DrawingNotes.LeaderNotes
'BendNote
If oLNote.Layer.Name <> oActObjDef.BendNoteLayer.Name
oLNote.Layer = oActObjDef.BendNoteLayer
End If
If oLNote.DimensionStyle.Name <> oActObjDef.BendNoteStyle.Name
oLNote.DimensionStyle = oActObjDef.BendNoteStyle
End If
For reset layer of oLNote.Layer you can set Nothing (null) to its value.
'oLNote.Layer = oActObjDef.BendNoteLayer
oLNote.Layer = Nothing
good suggestion, i did end up using that for ease of coding. however it didnt fix the problem. I managed to fix it because the Help API is a little misleading with what the bend notes are classified as. they aren't leader notes. they are their own catergory, DrawingNotes.BendNotes . but they behave like leader notes.
