iLogic dated sketch symbol
4 REPLIES 4
Formsprag
525 Views, 4 Replies
I have a "Temporary Drawing Stamp" sketch symbol that I am inserting through iLogic. It is a prompted entry symbol that requires a date. Is there a way to make the code default to the current date?
Here's the code:
'Sub Main()
' Set a reference to the drawing document.
' This assumes a drawing document is active.
Dim oDrawDoc As DrawingDocument = ThisDoc.Document
' Obtain a reference to the desired sketched symbol definition.
Dim oSketchedSymbolDef As SketchedSymbolDefinition _
       = oDrawDoc.SketchedSymbolDefinitions.Item("Temporary Dwg Stamp")
Dim oPromptStrings As String() = {"Enter Date"}
Dim oSheet As Sheet = oDrawDoc.ActiveSheet
'create insertion point, coordinates - in cm !
Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
Dim oInsertionPoint As Point2d = oTG.CreatePoint2d(10, 10)
    Dim sPromptStrings(0) As String
    sPromptStrings(0) = "Date"
' Add an instance of the sketched symbol definition to the sheet.
' Rotate angle = 0 radians,
' scale = 1 when adding
' no prompt text
Dim oSketchedSymbol As SketchedSymbol _
       = oSheet.SketchedSymbols.Add( _
             oSketchedSymbolDef, _
             oInsertionPoint, _
             0, 1, sPromptStrings)
'End Sub
4 REPLIES 4
Hi @Formsprag
in iLogic you can use DateString for this
I hope this helps.
Curtis
Hi
Great iLogic rule, almost exactly what I needed.
But I also need the current time. How would you add the current time to a second prompted entry in a sketch symbol? I can't work it out my self.
Here's what I came up with: (Remember your Sketch Symbol has to have two prompt entry fields)
'Sub Main()
    Dim sPromptStrings(1) As String
    sPromptStrings(0) = DateString
	sPromptStrings(1) = TimeString
' prompt text
             oInsertionPoint, _
Thank you! Worked like a charm.
The only thing I need to fix now is the date format. The DateString format is not the same as iProperties date format, which is th one I'd like to use. Is there a simple solution to fix this?
Technology Administrators
