I have written a program to find all sheet metal parts within an assembly and create DXFs from those files. Now, I would like to give the user the option to select which DXFs to create. Example: An assembly has 30 sheet metal parts but only 15 of them need DXFs. User selects those DXFs and runs the rest of the program.
I can read the file names from the assembly and generate the list, but I have no clue how to display a selectable list using Inventor's tools. Any suggestions?
Solved by DRoam. Go to Solution.
Solved by chandra.shekar.g. Go to Solution.
@Anonymous,
Hoping that below blog article would help to select multiple components.
https://adndevblog.typepad.com/manufacturing/2013/11/do-selection-from-ilogic.html
Try below iLogic code to select multiple components and generate DXF for selected occurrence.
Sub Main()
Dim comps As ObjectCollection
Dim comp As ComponentOccurrence
comps = ThisApplication.TransientObjects.CreateObjectCollection
While True
comp = ThisApplication.CommandManager.Pick(
SelectionFilterEnum.kAssemblyOccurrenceFilter,
"Select a component")
' If nothing gets selected then we're done
If IsNothing(comp) Then Exit While
comps.Add(comp)
End While
' If there are selected components we can do something
For Each comp In comps
Genereate_DXF(comp.Definition.Document)
Next
End Sub
Sub Genereate_DXF(doc As PartDocument)
'If check whether doc is Sheet metal or not
'Code to generate dxf from doc
End Sub
Thanks and regards,
hi @Anonymous, we've used InputBoxes for stuff like this before. It's not exactly pretty, but it works.
I pulled together some code from similar things we've done to build a framework for you. All it needs is the code you already have for determining sheet metal parts and exporting them.
Here's the resulting output on an assembly of ours:
It has some error handling built in, but I'm sure it's not bulletproof, so you may need to add more if any bugs pop up.
Hope it works well for your needs!
Here is the code:
Sub Main() Dim oRuleTitle As String = "Export to DXF" Dim oActiveDoc As Inventor.AssemblyDocument Try oActiveDoc = ThisApplication.ActiveDocument Catch MessageBox.Show("Please activate an Assembly document first.",oRuleTitle,MessageBoxButtons.OK,MessageBoxIcon.Error) Return End Try Dim oSMDocs As New List(Of Inventor.PartDocument) 'This is a list of all sheet metal documents that COULD be exported Dim oExportDocs As New List(Of Inventor.PartDocument) 'This is the list of sheet metal documents the user WANTS to export For Each oRefDoc As Inventor.Document In oActiveDoc.AllReferencedDocuments '~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ '~~~~~Your code that determines if the document is a sheet metal part~~~~~ '~~~~~~~~~~~~(My code currently just adds all Part documents)~~~~~~~~~~~~~ If oRefDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject Then IsSheetMetal = True Else IsSheetMetal = False End If '~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ If IsSheetMetal = True Then oSMDocs.Add(oRefDoc) End If Next 'oRefDoc oExportDocs.AddRange(oSMDocs) 'Begin by assuming user wants to export all sheet metal documents. 'Ask user to specify which documents to export Dim oInput As String Dim oIndex As Integer Dim oPartDoc As Inventor.PartDocument Do 'Populate list of all documents, with "checks" and numbering oDocList = CreateDocList(oSMDocs,oExportDocs) 'Display prompt with list and valid inputs oInput = InputBox( _ "Below is a list of all Sheet Metal parts. Items with an ""x"" will be exported to a DXF." & vbCrLf & _ vbCrLf & _ "Enter the number before an item to toggle its export setting. You can also enter a range like ""10-20"" (without quotes)." & vbCrLf & _ vbCrLf & _ "Enter ""a"" to toggle all" & vbCrLf & _ vbCrLf & _ oDocList & _ vbCrLf & _ "~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~" & vbCrLf & _ "To run export, hit Enter or click OK." & vbCrLf & _ vbCrLf & _ "To cancel, hit Escape or click Cancel." _ ,oRuleTitle, "r") 'Respond appropriately to user's input If oInput = "" Then Exit Do Else If oInput.ToLower = "r" Then Exit Do Else DashPos = InStr(oInput,"-") If IsNumeric(oInput) Or DashPos > 0 Or oInput.ToLower = "a" Then If IsNumeric(oInput) Then oStartNum = CDblAny(oInput) oEndNum = oStartNum Else If DashPos > 0 Then BeforeDash = Left(oInput,DashPos-1) AfterDash = Mid(oInput,DashPos+1) Try oStartNum = CDblAny(BeforeDash) oEndNum = CDblAny(AfterDash) Catch oStartNum = -1 oEndNum = -1 End Try Else If oInput.ToLower = "a" Then oStartNum = 1 oEndNum = oSMDocs.Count End If Try For i = oStartNum To oEndNum oIndex = i - 1 oPartDoc = oSMDocs.Item(oIndex) If oExportDocs.Contains(oPartDoc) Then oExportDocs.Remove(oPartDoc) Else oExportDocs.Add(oPartDoc) End If Next Catch oAnswer = MessageBox.Show("Please enter a valid number or range.",oRuleTitle,MessageBoxButtons.OKCancel,MessageBoxIcon.Error) If oAnswer = vbCancel Then oInput = "" Exit Do End If oValidRange = False End Try Else MessageBox.Show("Please enter a valid input.",oRuleTitle,MessageBoxButtons.OK,MessageBoxIcon.Error) End If 'Input is one that toggles some documents End If 'Input is... Loop Until oInput.ToLower = "r" Or oInput = "" If oInput = "" Then MessageBox.Show(oRuleTitle & " canceled.",oRuleTitle,MessageBoxButtons.OK,MessageBoxIcon.Information) Return End If 'Begin DXF export For Each oPartDoc In oExportDocs '~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ '~~~~~Your code that exports Sheet Metal part to DXF~~~~~ '~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Next '~~~~~Display final message~~~~~ MessageBox.Show("Finished exporting (" & oExportDocs.Count & ") sheet metal parts to DXF!",oRuleTitle,MessageBoxButtons.OK,MessageBoxIcon.Information) End Sub Function CreateDocList(oSMDocs As List(Of Inventor.PartDocument),oExportDocs As List(Of Inventor.PartDocument)) As String Dim oListText As String = "" Dim oItem As Integer = 0 For Each oPartDoc As Inventor.PartDocument In oSMDocs oItem = oItem + 1 If oExportDocs.Contains(oPartDoc) Then oCheckmark = "x" Else oCheckmark = " " End If oFilename = System.IO.Path.GetFileNameWithoutExtension(oPartDoc.FullFileName) oListText = oListText & "[" & oCheckmark & "] " & oItem.ToString("00.") & " " & oFilename & vbCrLf Next Return oListText End Function
Really excellent, this was exactly what I was looking for. The reply above is also useful, I think both could work.
Great! Yeah, I could see there being usefulness for both methods, either selecting the desired parts in the Assembly or selecting from a list. You could probably incorporate both methods into the same rule -- if a selection is present when the rule starts (If oDoc.SelectSet.Count > 0), then export the selected parts; otherwise, present the user with the list.
Best of luck!
