Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
iLogic component browser names
12 REPLIES 12
Message 1 of 13
2600 Views, 12 Replies
I am stabilizing many component names in assemblies for use in iLogic rules. But this has lead to many complaints about no longer being able to identify the file name easily.
Is there a setting in Inventor that could display the file name next to the display name? Or another quicker method than accessing iProperties or the BOM dialog to see file names.
12 REPLIES 12
Message 2 of 13
I thought I was onto something when I read this on the Inventor help page
"You can change the component back to its original name and still preserve its stability. To change the component, make a minor change to the name, and then change it back to the original."
But I don't understand how this works in practice, changing the name back removes its stability and the rules that reference it no longer work.
Message 3 of 13
Hi @Anonymous
Component's browser name settings can be changed from "Assemble<Productivity<Rename Browser Nodes" tab on Ribbon
Browser name can be changed to File Name or Part Number or Default
Thanks & Regards,
Tushar
Message 4 of 13
@Anonymous
Thanks, but I was hoping there would be a way of keeping the browser names stabilized (as they are referenced in iLogic rules), but somehow show their part number or file name as well in the browser. Renaming the browser nodes causes the rules to fail.
Message 5 of 13
Curtis_Waguespack
Hi c.henderson2HQZG,
Could you create a custom iProperty called something like "Stabilized Name", and then before the rule runs, have the display name change to use that iProperty, and then at the end of the rule have it change to use the file name?
I would make this 2 separate external iLogic rules and then run the 1 rule at the beginning of your other rules, and the 2nd at the end.
I've been intending to write something like that for a while, because I'm like your users and prefer to see the file names, but just haven't stopped to do it yet.
Post back if you try it and it doesn't work and I'll to take a closer look.
I hope this helps.
Curtis
Message 6 of 13
NachitoMax
Hi
I wrote 2 functions a while ago that I'm happy to share.
Routine 1
Renames the browser node to the display name of the document referenced in the first view on each page
Routine 2
Resets the sheet names to Sheet
If you think they will help, let me know and I'll send then tomorrow evening
Nacho
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
Message 7 of 13
in reply to: NachitoMax
@NachitoMax Yeah please, hopefully that could give me a good start to achieve something like @Curtis_Waguespack has suggested above.
Thanks guys, much appreciated!
Message 8 of 13
NachitoMax
Hi
Here is the code I mentioned (also see attached video of it working)-
Rename Sheets
Add 'RenameSheets' to the ribbon as a button
When clicked, it will rename each sheet to the name of the referenced object in the 1st drawing view
Public Sub ReNameSheets()
Dim oDoc As DrawingDocument
Set oDoc = ThisApplication.ActiveDocument
Dim osheets As Sheets
Set osheets = oDoc.Sheets
Dim oSheet As Sheet
Set oSheet = oDoc.ActiveSheet
Dim defSheetLabel As String
defSheetLabel = oDoc.SheetSettings.SheetLabel
Dim sCount As Integer
For Each oSheet In osheets
    On Error Resume Next
    'oSheet.Activate
    Dim oDrawingView As DrawingView
    Set oDrawingView = oSheet.DrawingViews(1)
    omodelname = oDrawingView.ReferencedDocumentDescriptor.ReferencedDocument.DisplayName
oSheet.Name = omodelname & " - " & defSheetLabel
Next
End Sub
Reset Sheets
Add 'ResetSheets' to the ribbon as a button
When clicked, it will rename all sheets to the generic 'Sheet'
Public Sub ResetSheets()
Dim oSheet As Sheet
    'oSheet.Activate
oSheet.Name = defSheetLabel
Next
Nacho
Message 9 of 13
Any chance you got around to this?...Smiley Surprised
Message 10 of 13
Hi JimmyDoe,
Sort of.
Here's an example that gets the stabilized name and writes it to a custom iprop, and then toggle the browser name to the be the file name, or vice versa.
Experiment with this on a test assembly in case it's buggy, as it could wipe out your stabilized names.
Note too that as written it uses the assembly name as part of the custom iProp, so that a file used in multiple assemblies can have multiple "stabilized" names. Meaning that you'd have multiple custom iprops in the part file. You can remove that if needed, and just have it write to the same iprop if you want.
I hope this helps.
Curtis
'check for variable to hold inputradiobox value
If SharedVariable.Exists("Input_Value") = False Then
	SharedVariable("Input_Value") = True
End If
'get user input
sOption1 = "Browser currently has Stablized Names"
sOption2 = "Browser currently has File Names"
bStabilizedName = InputRadioBox("Select an option:", sOption1, sOption2, _
	SharedVariable("Input_Value"), "iLogic - Toggle browser names")
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
oAssemblyName = _
System.IO.Path.GetFileNameWithoutExtension(ThisApplication.ActiveDocument.FullFileName)
oIpropName = "Stabilized_Name_" & oAssemblyName
'Iterate through all of the occurrences
Dim oOcc As ComponentOccurrence
For Each oOcc In oAsmCompDef.Occurrences.AllReferencedOccurrences(oAsmCompDef)
	docFile = oOcc.Definition.Document
    docName = System.IO.Path.GetFileNameWithoutExtension(docFile.FullFileName)
	If bStabilizedName = True Then
		iProperties.Value(oOcc.Name, "Custom", oIpropName) = oOcc.Name
		'clear browser name override by setting to nothing
		'which resets it to file name
		oOcc.Name  = ""
		'set variable to hold inputradiobox value
		SharedVariable("Input_Value") = False
	Else
		'set occurence name to stablized name
		oOcc.Name = iProperties.Value(oOcc.Name, "Custom", oIpropName)
		'set 'variable to hold inputradiobox value
	End If
Next
Message 11 of 13
    		oParent = System.IO.Path.GetFileNameWithoutExtension(docFile.FullFileName)
I used the above part from your rule: that is working. But could I extract the file extension.
I appreciate if you could reply, Thanks.
Message 12 of 13
Hi Curtis;
Please disregard my previous request. I m getting it around
'    		oParent = System.IO.Path.GetFileNameWithoutExtension(docFile.FullFileName)
    		oParent = System.IO.Path.GetFileName(docFile.FullFileName)
All the best.
Message 13 of 13
maxim.teleguz
c = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAllEntitiesFilter, "Select component")
d = Component.InventorComponent(c.name).Definition.Document.FullFileName
f = IO.Path.GetFileNameWithoutExtension(d)
MsgBox(f)
