iLogic code to close ipt file....
4 REPLIES 4
5144 Views, 4 Replies
Hello!
Can someone help me with this? Looking for the ilogic code to place in the drawing rule to close *.ipt file that was recently open.
Thank you, Any help appreciated
4 REPLIES 4
Also looking for the way to switch between open tabs drawings or ipt, iam files.
Thank you.
ok. I found the solution.
Thank you.
Dim oPart As PartDocument
oPart = ThisApplication.Documents.Open(filename, False)
oPart.Close
mwighton
how would you close an assembly file?
Did this post help out? Hope it did.
If so please use the 'Accept as Solution' or 'Kudos' Button below.
God Bless
Mwighton
mwighton
in reply to: mwighton
i figured it out. I was missing the extension for the file name i was trying to close.
SyntaxEditor Code Snippet
opendoc = ThisDoc.PathAndFileName()'saves doc path and file name
doc = ThisApplication.Documents.Open(opendoc & ".iam")'saves 'doc' as the open application from 'opendoc' adding the extension '.iam'
doc.Close 'closes the indicated document 'doc'
God Bless
Mwighton
Technology Administrators
