I have a rule, which open selected idw-Files, export them to pdf and dwg and close them.
For big drawings, some views don't look fully drawn:
I guess, it's because the exports starts right after opening and the views are not rendered completly (green borders). I need to check, if every view is rendered.
Any ideas?
Hi @m.Bongartz
You could have the code check for raster views first.
I hope this helps.
Curtis
Dim oDrawDoc As DrawingDocument
oDrawDoc = ThisApplication.ActiveDocument
For Each oSheet In oDrawDoc.Sheets
For Each oView In oSheet.DrawingViews
If oView.IsRasterView = True Then
MsgBox("Warning one or more views is a raster view", , "iLogic")
Return
End If
Next
Next
This work so far. Thanks!!
This issue is not reproduceable, therefore debugging and testing is not that easy. I will test it for a while and share my results.
Here my code:
'load drawing
For Each oSheet In oDrawing.Sheets
oSheet.Activate()
'check if every view is not in rasterView
While (checkRasterViews(oSheet))
oSheet.Update()
End While
Next
'export drawing
'close drawing
Function checkRasterViews(oSheet As Sheet) As Boolean
'return True if all views are not on RasterMode
checkRasterView = True
If oView.IsRasterView Then
'View is in Raster Mode --> check unsuccessful
checkRasterView = False
Logger.Warn(oView.Name & "is in RasterView")
Exit For
End If
Next
End Function
The DrawingView object also has a couple other Properties you may want to check also, like 'DrawingView.UpToDate' & 'DrawingView.IsUpdateComplete'. But I think maybe the one that may be the best fit would be the Sheet's Property called 'Sheet.Status', which uses the 'DrawingSheetStatusBits' enumerator to help you, obviously, determine the current 'status' the sheet. You can add these to your arsenal/toolbox for making sure the sheet/views are up to date, before publishing/exporting.
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click (LIKE or KUDOS) 👍.
If you want and have time, I would appreciate your Vote(s) for My IDEAS :light_bulb:or you can Explore My CONTRIBUTIONS
Wesley Crihfield
(Not an Autodesk Employee)
I use DrawingOptions.EnableBackgroundUpdates = false just before opening the drawing. It has worked flawlessly in a PDF Exporter app I wrote to export all component PDFs from an assembly.
You can store the current setting before starting any exporting, set to false before doing work, then finally change the setting to what it was when you're done. This way, you don't have to iterate over each View, Sheet, Drawing, etc. Every drawing will always be ready for PDF export. If you're only doing one drawing at a time, maybe the above suggestions work better for you.
