Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Ilogic before ''save as'' command
5 REPLIES 5
s_sanders
428 Views, 5 Replies
I want to fire a Ilogic rule in a ipt template, when i use the event ''before save'' the rule is not fired because the first save is the save as command.
The rule get the extended dimensions of a plate, and creates a custom iproperty and filename.
5 REPLIES 5
johnsonshiue
in reply to: s_sanders
Hi! Please share the file here so forum experts can take a look. It should be doable.
Many thanks!
Software Test Engineer
s_sanders
in reply to: johnsonshiue
Now i have run the next codes through a form
ThisDoc.Document.Rebuild()
On Error Resume Next
Dim oDoc As PartDocument
oDoc = ThisApplication.ActiveEditDocument
Dim CadlineSheetMetal As SheetMetalComponentDefinition
CadlineSheetMetal = oDoc.ComponentDefinition
CadlineSheetMetal.FlatPattern.Delete
CadlineSheetMetal.Unfold
Cadline = ThisApplication.ActiveDocument.ComponentDefinition
X= 10*( Cadline.RangeBox.MaxPoint.X - Cadline.RangeBox.MinPoint.X)
Y= 10*( Cadline.RangeBox.MaxPoint.Y - Cadline.RangeBox.MinPoint.Y)
Z= 10*( Cadline.RangeBox.MaxPoint.Z - Cadline.RangeBox.MinPoint.Z)
Parameter.Quiet = True
THICKNESS = MinOfMany(X, Y, Z)
LENGTH = MaxOfMany(X, Y, Z)
If X < LENGTH Then
WIDTH = X
End If
If Y < LENGTH Then
WIDTH = Y
End If
If Z < LENGTH Then
WIDTH = Y
End If
iProperties.Value("Custom", "Lengte") = Round(LENGTH, 0)
iProperties.Value("Custom", "Breedte") = Round(WIDTH, 0)
iProperties.Value("Custom", "Dikte") = Round(THICKNESS, 0)
Parameter("Lengte") = Round(LENGTH, 0)
Parameter("Breedte") = Round(WIDTH, 0)
Parameter("Dikte") = Round(THICKNESS, 0)
RuleParametersOutput()
iLogicVb.UpdateWhenDone = True
oDoc = ThisApplication.ActiveDocument
InventorVb.DocumentUpdate()
ThisDoc.Save
iLogicVb.RunRule("Part number naam")
Second running this:
iProperties.Value("Project", "Part Number") = "PLAAT " & CStr(Lengte) & "x" & CStr(Breedte) & "x" & CStr(Dikte)
ThisDoc.Document.DisplayName = iProperties.Value("Project", "Part Number") & iProperties.Value("Project", "Project") & ".ipt"
ThisApplication.CommandManager.ControlDefinitions.Item("AppIsometricViewCmd").Execute
ThisApplication.CommandManager.StartCommand(CommandIDEnum.kFileSaveCommand)
Can this codes be combined? And fired by the save and save as command?
Thanks in advance
MjDeck
@s_sanders , do you want the rule to set the initial filename when you save for the first time after creating the part from the template?
It seems that the overall size of a part could change in future, but the filename would still display the initial size.
Mike Deck
Software Developer
s_sanders
in reply to: MjDeck
Only set the initial filename is ok for us.
MjDeck
The problem is that the Before Save Document event happens *after* you see the Save As dialog. So you don't get a chance to set the filename in a rule on Before Save.
If seems like you have to set the display name before you save. Maybe the way you're doing it now (running from a form) is the best way.
Mike Deck
Software Developer
