Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
iLogic basic math equation returns wrong value?
2 REPLIES 2
william
383 Views, 2 Replies
Hello Everybody
I type the below equation into ilogic:
Carcase_OAL_A = Tan(Corner_Angle_A/2) * Booth_Depth
Corner_Angle_A = 60deg
Booth_Depth = 635mm
I should get a value of 366.617 for Carcase_OAL_A
Instead I get -4067.38mm
I type it in like this:
Carcase_OAL_A = Tan(Corner_Angle_A / 2 ul ) * Booth_Depth
I get -4067.38mm again
Carcase_OAL_A = Tan(30) * Booth_Depth
I type in this equation:
Carcase_OAL_A = Tan(Corner_Angle_A) * Booth_Depth
I get a value of 203.22mm
It does not let me divide the angle parameter within the tan brackets. When i hover the mouse over the tan function the example shows a equation within the tan brackets. Capture.JPGCan anyone explain what is going on?
2 REPLIES 2
JhoelForshav
in reply to: william
Hi @william
The Tan-function takes arguments in radian, not degree. Since your parameter is in degree you'll have to convert it its corresponding radian value. Like so:
Carcase_OAL_A = Tan(Corner_Angle_A/2 * PI/180) * Booth_Depth
william
in reply to: JhoelForshav
Thankyou
