what i am trying to do is create an iLogic rule that if your drawing view scale is set to the following ...
1:1, 1:2, 1:4, 1:8, 1:12, 1:!6, 1:24, 1:32, 1:48, etc. on the view label for that view it will diplay ...
SCALE: 1/2" = 1'-0"
and so on for the rest for the standard scale factors.
i know it will be some sort of a loop and it needs to check all views when ran for any changes.
i have never done any coding for the drawing side of inventor yet only model coding so an help will
be greatly appreiciated.
Solved by jdkriek. Go to Solution.
Much simpler solution
In your drawing template got to your style editor
Click on your standard. In the general tab you will see "Preset Values" section.
Change the dropdown to "Scale"
Here you can enter all the scales that you want to be available for views.
See attached 😉
for as long as i have been using inventor i never knew you can call your scale factor out that way. still learning everyday
Just for the heck of it, thought I would write your orginal request for your legacy drawings 🙂
Note, I only included "1 : 1" with the spaces in between, you can change this to "1:1" if yours is currently displayed like that. Add more by adding more "Cases". Always leave the "& Chr(34)" on the end.
Dim oApp As Application: oApp = ThisApplication Dim oDoc As DrawingDocument: oDoc = oApp.ActiveDocument Dim oSheets As Sheets Dim oSheet As Sheet Dim oViews As DrawingViews Dim oView As DrawingView oSheets = oDoc.Sheets For Each oSheet In oSheets oViews = oSheet.DrawingViews For Each oView In oViews Select Case ActiveSheet.View(oView.Name).ScaleString Case "1 : 1" ActiveSheet.View(oView.Name).ScaleString = "1'=1'-0" & Chr(34) End Select Next Next
Thank you so much for the extra effort in writting me the code. its people like you that are helping me to understand the Inventor API.
I also can't change my scale format in Inventor Prof 2012. I want to open a sheet with scale 1:2 but there is only 1:1 , I tired to change by using edit sheet option but I couldn't manege it 😞 i need some help.
Sinan KAYA
