iLogic and System.Windows.Forms - allow to interact with Inventor GUI
j.pavlicek
j.pavlicek
is possible to let user interact with Inventor GUI when is System.Windows.Forms.Form displayed by iLogic? (By default, a form window is keeping focus in context of Inventor app.)
I think there is probably limitation - no GUI interaction with Inventor when iLogic is running, I'd like to be sure.
Inventor 2022, Windows 10 Pro
Sorry for bad English.
JelteDeJong
How do you start the form? If i remember correct it can be done with Form.ShowDialog() that will block the thread but it can also be started with Form.Show() that will not bock the thread.
If that does not help you could start the form on a new thread.
Jelte de Jong
Blog: hjalte.nl - github.com
marcin_otręba
Set modal parameter to false :
Hi, maybe you want to check my apps:
DrawingTools   View&ColoringTools   MRUFolders
j.pavlicek
Thank you.
Form.Show()
 instead of
Form.ShowDialog()
does the trick!
j.pavlicek
Hi, thanks for reply.
Although your answer is not related to System.Windows.Forms, it's good to know it!
