Hello Community,
I've been using inventor for rougly 6 months now, and I lurk on the forums almost every day and notice everyone talks about ilogic. My question is that is it worth it? how much easier does it make drawing?
I do sheet metal, ie counter- tops, shelves, floor troughs, and don't really see the point in iLogic for what i do.
I've attached a part to better understand what items i draw up and get fabricated in our shop.
But I'm always down to learn and maybe I'm just missing the point.
Also with commands, every time i try to customize a command, i can't make it a two button command.
Every time i try to use alt or ctrl plus another key, it always tells me that its not a command and resets to default.
ive been just making my commands like double tapping. For instance, in order to save my view as a pdf, i just double tap "0" on my keypad.
Any way i can use alt and ctrl to my pleasing and not just the defaults?
