Use iLogic to add Description to Leader Text
el_jefe_de_steak
el_jefe_de_steak
Hi, I'm trying to use iLogic to add the linked model property "description" to my leader text. However, this code does not work for me. Any ideas on how to fix it? This code works great for changing view labels.
If ThisApplication.ActiveDocumentType <> kDrawingDocumentObject Then
	MessageBox.Show("This rule only works in a drawing document.", "Change Leader Text",MessageBoxButtons.OK,MessageBoxIcon.Error)
	Return
Dim oDoc As DrawingDocument
oDoc = ThisApplication.ActiveDocument
Dim oLeaderNote As LeaderNote
saveOriginalText = False
addDescription = False
Question = MessageBox.Show("Overwrite existing leader text?", "Change Leader Text",MessageBoxButtons.YesNoCancel,MessageBoxIcon.Question,MessageBoxDefaultButton.Button1)
Select Case Question:
Case vbYes
Case vbNo
	saveOriginalText = True
Case vbCancel
	Return
End Select
'define model property values
oDescription = "<Property Document='model' PropertySet='Design Tracking Properties' Property='Description'>DESCRIPTION</Property>"
For Each oLeaderNote In oDoc.ActiveSheet.DrawingNotes
	'saves the original text
	originalText = oLeaderNote.FormattedText
	oLeaderNote.FormattedText = oDescription
	'adds original beginning to end of label text if applicable
	If saveOriginalText = True Then
		oLeaderNote.FormattedText = oLeaderNote.FormattedText & vbCr & originalText
Next
el_jefe_de_steak
This code works fine as is...
There was an error in my original code which I mindlessly fixed while formatting it for putting it on the forum.
A.Acheson
Thanks for posting this code. I found an error, where the collection the code was trying to modify was omitted.
Error on this line collection in red was omitted.
For Each oLeaderNote In oDoc.ActiveSheet.DrawingNotes.LeaderNotes
Below code is working now.
	Return
Case vbYes
Case vbNo
Case vbCancel
	Return
End Select
Next
Regards
Alan
