@MjDeck (or anyone else) , can you tell us if this is working as expected, and if so why the 2nd run of the rule moves the dimension up and how we might adjust this to keep it in place and aligned with the other dimension. See images below and attached 2025 files.
Thank you,
Curtis
Before running the rule
After running the rule once
After running the rule twice
