iLogic Add Dimension with extra text changes location
Curtis_Waguespack
Consultant Consultant
Curtis_Waguespack
@MjDeck  (or anyone else) , can you tell us if this is working as expected, and if so why the 2nd run of the rule moves the dimension up and how we might adjust this to keep it in place and aligned with the other dimension. See images below and attached 2025 files.
Thank you,
Curtis
Before running the rule
After running the rule once
After running the rule twice
MjDeck
Hi Curtis - iLogic is moving the dimension text to the wrong position. This only happens if the dimension is already there. To work around the problem, add these lines to the rule, before creating the dimensions:
ThisDrawing.DeleteManagedEntity("Dimension 1")
ThisDrawing.DeleteManagedEntity("Dimension 2")
This is a known problem: INVGEN-76775. We should be able to fix it soon.
Mike Deck
Software Developer
Autodesk, Inc.
