Identify constraints on a particular part inside a sub-assembly with iLogic
nick5MWHR
Message 1 of 9
nick5MWHR
I've bassicaly got the some question as @DRoam ... However, I'm keen on using iLogic so I'm curious if it is possible.
https://forums.autodesk.com/t5/inventor-forum/identify-constraints-on-a-particular-part-inside-a-sub...
I'm currently checking if a property of all parts in an assembly (and subassamblies) have a property "IO Type" and if this IO Type contains cable, I want to know to what part this is attached. The code is working;however, I'm struggling with the same part as @DRoam... If the cable is directly constrained to a part I'm retrieving the part, but when the cable is connected to a subassembly, I'm retrieving the subassembly.
I'm wondering if it is possible to retrieve the part? I read something about proxy but I don't know how to use that and if it can be achieved using proxy.
Keep in mind that the code below is part of a bigger code. This is just the part that checks if the part contains the property and if that property equals cable.
	If sFileName.Contains(".ipt") And sBomstructure.Contains("kPurchased") And Not sFileName.Contains("DIN") And Not sFileName.Contains("ISO") Then
		Try
			IOType = iProperties.Value(sFileName, "Custom", "IO Type")
		Catch
		End Try
		If IOType <> "" Then
			sPartNumber = iProperties.Value(sFileName, "Project", "Part Number") 'Everything contains a Part Number
			Try
				sFabricationNumber = iProperties.Value(sFileName, "Custom", "Fabrication Number") 'Not everything has a fabrication number
			Catch
			End Try
			If IOType = "Cable" Then
			'Check to what assembly/part the cable is connected.
				For Each CableConstraint As AssemblyConstraint In oComp.Constraints
					If Not IsNothing(CableConstraint.OccurrenceOne) And Not IsNothing(CableConstraint.OccurrenceTwo) Then
						If CableConstraint.OccurrenceOne.Name <> oComp.Name Then
							IOAttached = CableConstraint.OccurrenceOne.Name
						Else
							IOAttached = CableConstraint.OccurrenceTwo.Name
					Exit For
				Next
Replies (8)
Message 2 of 9
m_baczewski
Check this.
		Try
		Catch
		End Try
			Try
			Catch
			End Try
'							IOAttached = CableConstraint.OccurrenceOne.Name
							IOAttached = CableConstraint.EntityOne.ContainingOccurrence.Name ' <---
						Else
'							IOAttached = CableConstraint.OccurrenceTwo.Name
							IOAttached = CableConstraint.EntityTwo.ContainingOccurrence.Name ' <---
					Exit For
				Next
Message 3 of 9
nick5MWHR
Thank you! That seems to do the trick!
May I ask how you found that command? It doesn't "pop-up" as a suggestion like EntityOne for example.
Message 4 of 9
m_baczewski
Personally, I use the Inventor API. Recently, I saw someone insert an interactive PDF that illustrates the API. I personally use the API directly through macros and adding "addwatch" to review a given model/part.
Here is a link to the forum post with the PDF of the API: https://forums.autodesk.com/t5/inventor-programming-ilogic/inventor-api-object-model-diagramm-linked...
And an interesting fact: if you define a variable as FaceProxy, you will have access to all properties and methods
Dim fProxyEntityOne As FaceProxy = CableConstraint.EntityOne
MsgBox(fProxyEntityOne.ContainingOccurrence.Name)
Message 5 of 9
nick5MWHR
Thanks. If I use the PDF, it sends me to this website. However, I can't see what the "object" contains?
https://help.autodesk.com/view/INVNTOR/2022/ENU/?guid=AssemblyConstraint_EntityOne
The FaceProxy seems to work!
In what are you programming to use the Inventor API, visual studio?
Edit: Wrong link
Message 6 of 9
m_baczewski
At work, I write in Visual Studio, the iLogic editor, and VBA. I mainly use .NET Framework (C#). To better understand the Inventor API, take a look at this.
Follow the steps in the pictures:
Enter this code in Module1:
Sub main()
Dim odoc As Document
Set odoc = ThisApplication.ActiveDocument
End Sub
Then, press F8 to step through to the line End Sub. Next, hover over odoc, right-click, and select "Add Watch". Now you will have access to what is happening in the application and what type you are dealing with. You can expand the individual branches and explore the Inventor program. This is how I learned the API.
Message 7 of 9
WCrihfield
Hi @nick5MWHR.  Pertaining to your question about where/how to program using Inventor's API...
We usually either work with Inventor's API through iLogic rules, or through the VBA Editor dialog.  But I quit using VBA years ago, not only because it is very outdated, but also because Microsoft (its developer/maintainer) stopped maintaining it years ago, making it dangerously unsecure, which is why they stopped including it in standard Inventor installations years ago.  We can also work with Inventor's API through Visual Studio, if you have Visual Studio set-up properly, and have included the references needed to understand the Inventor API Object model.  However, when working within Inventor's iLogic Rule Editor dialog, and iLogic rules, we have extra resources available to us that are not available from within the VBA Editor...and are not available from Visual Studio either, without some extra references and preparations.  This is because iLogic itself is an ApplicationAddIn within Inventor, with its own API (unlike most other Inventor add-ins), resources, and user interface that are unique to it, making many actions shorter and/or simpler to achieve by code.
Inventor API User's Manual
iLogic
iLogic API Overview
Wesley Crihfield
(Not an Autodesk Employee)
Message 8 of 9
_dscholtes_
According to the API help, EntityOne should be defined as an Object (because it can be any kind of geometric entity, it's not restricted to a FaceProxy).
I use VBA as well to develop macro's, but I use the 'Locals' window instead of the 'Watch'  window in combination with a conveniently placed break statement in the code to find interesting properties. Also, the object browser in the VBA IDE (F2) is great source of object properties/methods.
Message 9 of 9
m_baczewski
Exactly as you say, in this case, I wanted to illustrate that when we define a variable as a certain type, we can see the methods and properties available for that type.
