How to select a pattern and suppress a element of pattern using ilogic
aniketpunwatkar
aniketpunwatkar
I have been working on a project where I wanted user to pick pattern ,and enter the number of a element to suppress.
Here is my ilogic code for your help:
Imports Inventor
Dim doc As AssemblyDocument
doc = ThisApplication.ActiveDocument
' Attempt to pick an occurrence pattern
Dim selectedPattern As OccurrencePattern
selectedPattern = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyOccurrencePatternFilter, "Select a pattern")
If Not IsNothing(selectedPattern) Then
' Correctly reference the selected pattern
Dim oPattern As OccurrencePattern
oPattern = selectedPattern
' Get user input for the pattern element index
myparam = CInt(InputBox("Enter a value greater than 1", "Input", 2))
' Suppress the specified element in the pattern
If myparam > 0 And myparam <= oPattern.OccurrencePatternElements.Count Then
Dim oElement As OccurrencePatternElement
oElement = oPattern.OccurrencePatternElements.Item(myparam)
oElement.Suppressed = True
Else
MsgBox ("Invalid index. Please enter a value between 1 and ")
Else
MsgBox ("No pattern selected.")
AndrewHumiston
Afternoon,
here is the code i came up with. there is a filter set to only allow for slection of patterns and an input box that will show the max number of instances.
Dim oAssyDoc As AssemblyDocument = ThisApplication.ActiveDocument
'select edge for second chamfer input
Dim oSelection As Object = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyOccurrencePatternFilter, "Select First Chamfer Edge")
Dim Ans As Integer = InputBox("Set instance Number to Suppress" & vbNewLine & "From 1 to " & oSelection.OccurrencePatternElements.Count, "Suppress Instance", "#")
oSelection.OccurrencePatternElements.Item(Ans).Suppressed = True
please accept as solved if this meets your needs.
please reach out with any other questions. thank you!
