Identify beam and continue rule otherwise exit
Benjaaamin
Benjaaamin
Hi folks,
I have the below snippet 'Select Beam' which pulls through the parameters of a frame gen beam and holds them locally in the assembly level parameters.
Dim doc = ThisApplication.ActiveDocument
Dim BeamPick = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyLeafOccurrenceFilter,"Select Beam")
	If (Not BeamPick Is Nothing) Then
    	oBeamName = BeamPick.Name
	End If
'Beam parameters are extracted to local assembly parameters
	Beam = BeamPick.Name
		SPL_W1 = Floor(Parameter(Beam, "G_W")/2 - (Parameter(Beam, "G_T")/2))-SetBack
		SPL_L1 = Floor(Parameter(Beam, "G_H") -(2 * (Parameter(Beam, "G_T1")))) -HSetBack
		DPL_H = Parameter(Beam, "G_H")
		Web = Parameter(Beam, "G_T")
		Flange = Parameter(Beam, "G_T1")
		Rad = Ceil(Round((Parameter(Beam, "G_IR") + 2)) / 5) * 5
End If
RuleParametersOutput()
InventorVb.DocumentUpdate()
ThisApplication.ActiveView.Fit
If the incorrect component is selected I get the following error -
What I'm looking to achieve is a means of rather than getting an error is to exit the rule.
Can anyone suggest something I can add to my snippet that can do this? Would this pull some kind of detail from the iproperties?
I also have a similar rule called 'Select SHS' that I would like to achieve the same thing with.
Any help is appreciated!
Michael.Navara
You can use Try-Catch block. this is the easiest way. Or you need to check the picked component if it contains all required parameters.
nstevelmans
Hi, Maybe this can help
Dim oCC As ComponentDefinition
Dim oPartdoc As PartDocument
Dim BeamPick As ComponentOccurrence
 BeamPick = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyLeafOccurrenceFilter, "Select Beam")
Try
End If
	 Catch
	MsgBox("Missing Parameters in " & BeamPick.Name & ".ipt" &" Open the Part en check if G_IR,G_T1,G_H,G_W exist",MsgBoxStyle.Critical, "Missing Parameters")
End Try
Benjaaamin
@nstevelmans you are a legend! Exactly what I was wanting!
Cheers
Type a product name
