Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
iassembly generate files using external rule
2 REPLIES 2
cmcewanE2U82
190 Views, 2 Replies
Looking to be able to generate files without selecting them (by highlighting) right clicking generate files and then having to hit ok during each factory member generation.
Is there a way I can bypass clicking ok on every file being generated?
I have a macro on my keyboard that repeatedly presses enter to sort of automate this but there has to be a more official way.
I want a button/external rule I can run that takes care of generating all the files so I can share it with my team so save monotonous button clicking/key pressing for dozens of files daily.
Labels (3)
2 REPLIES 2
WCrihfield
in reply to: cmcewanE2U82
Hi @cmcewanE2U82.  I do not currently use iAssemblies, but I think the following code example should work for a task like that.
Sub Main
	Dim oADoc As AssemblyDocument = TryCast(ThisDoc.Document, Inventor.AssemblyDocument)
	If oADoc Is Nothing Then Return
	Dim oADef As AssemblyComponentDefinition = oADoc.ComponentDefinition
	Dim oFactory As iAssemblyFactory = Nothing
	If oADef.IsiAssemblyFactory Then
		oFactory = oADef.iAssemblyFactory
	ElseIf oADef.IsiAssemblyMember Then
		oFactory = oADef.iAssemblyMember.ParentFactory
	End If
	If oFactory Is Nothing Then Return
	'Dim sMembersFolder As String = oFactory.MemberCacheDir
	For Each oRow As iAssemblyTableRow In oFactory.TableRows
		oFactory.CreateMember(oRow)
	Next
End Sub
If this solved your problem, or answered your question, please click ACCEPT SOLUTION .
Or, if this helped you, please click (LIKE or KUDOS) 👍.
Wesley Crihfield
(Not an Autodesk Employee)
cmcewanE2U82
in reply to: WCrihfield
Thankyou I will give it a try and see how it behaves.
Technology Administrators
