I currently have a rule that runs in an assembly edit environment on a part. Once you are editing a part in an assembly, you can run this rule and it allows you to select a face on the part and it projects all cut edges to the part face as well as projecting the border of the part face. Then, it removes all geometry found outside of the face border and splits/trims lines found outside the face border by finding their intersection, deleting the lines then redrawing them. This works perfectly, except it does not work for curved entities like arcs, circles, splines etc. It does detect that part of the curved geometry intersects with the face border, but instead of trimming to that intersection it just deletes the curved geometry entirely. How do I alter my code so that it "trims" these curved entities to the face border line instead of deleting it entirely? The attached photos are a simplified version of what I'm looking to do with iLogic. I have also attached my current code below (it runs on a part being edited in an assembly):
Public Sub Main()
' Declare the application object and get the current application
Dim oApp As Inventor.Application = ThisApplication
Dim oDoc As Inventor.Document = oApp.ActiveDocument
Dim oAssDoc As Inventor.AssemblyDocument = oApp.ActiveDocument
Dim oAssDocDef As Inventor.AssemblyComponentDefinition = oAssDoc.ComponentDefinition
Dim oFaceProxy As FaceProxy = Nothing
Dim oSketch As PlanarSketch = Nothing
Try
' Prompt user to select a face
oFaceProxy = oApp.CommandManager.Pick(SelectionFilterEnum.kPartFaceFilter, "Pick a face")
If oFaceProxy Is Nothing Then
MessageBox.Show("No face was selected.")
Return
End If
Catch ex As Exception
MessageBox.Show("Error in selecting face: " & ex.Message)
Return
End Try
' Define an empty list to hold occurrences touching the selected face
Dim oOccurrenceListA As New List(Of ComponentOccurrence)
Try
' Iterate through the occurrences in the assembly to find parts touching the selected face
For Each oOccurrence As ComponentOccurrence In oAssDocDef.Occurrences
' Check each occurrence against the selected face to find touching parts
If oApp.MeasureTools.GetMinimumDistance(oOccurrence, oFaceProxy) < 0.01 AndAlso Not oOccurrence Is oFaceProxy.ContainingOccurrence Then
oOccurrenceListA.Add(oOccurrence)
End If
Next
MessageBox.Show("Error finding touching parts: " & ex.Message)
Return
End Try
' Check if any parts are touching the selected face
If oOccurrenceListA.Count = 0 Then
' If no parts are touching, notify the user and exit the sub
MessageBox.Show("No parts touching the selected face. No scribe lines will be created.", "No Parts Touching")
Return
End If
Try
' Set the default sketch name
Dim defaultSketchName As String = "SCRIBE LINES"
' Prompt the user to name the sketch
Dim userInputName As String = InputBox("Please enter a name for the new sketch:", "Name Sketch", defaultSketchName)
' Access the occurrence containing the face
Dim oOcc As ComponentOccurrence = oFaceProxy.ContainingOccurrence
' Access the part document's component definition
Dim oMainPartDef As PartComponentDefinition = oOcc.Definition
' Check if the user input is empty, set it to the default name
Dim sketchName As String = If (String.IsNullOrWhiteSpace(userInputName), defaultSketchName, userInputName)
Dim sketchNumber As Integer = 1
' Check if the sketch name already exists and create a unique name if necessary
While oMainPartDef.Sketches.OfType(Of PlanarSketch).Any(Function(s) s.Name.Equals(sketchName, StringComparison.OrdinalIgnoreCase))
' If the user did not provide a unique name, append a number to make it unique
If sketchName = defaultSketchName OrElse sketchName.StartsWith(defaultSketchName & " ") Then
sketchName = defaultSketchName & " " & sketchNumber
sketchNumber += 1
Else
' If the user provided a unique name but it's not unique, prompt again
sketchName = InputBox("The sketch name is already in use. Please enter a unique name for the new sketch:", "Name Sketch", userInputName)
' Reset the counter if the user is providing names manually
sketchNumber = 1
' If the user cancels the prompt, exit the sub
If sketchName = "" Then Return
End If
End While
' Initialize the sketch variable with the unique name
oSketch = oMainPartDef.Sketches.Add(oFaceProxy.NativeObject)
oSketch.Name = sketchName
oSketch.Edit() ' Start the sketch editing mode
MessageBox.Show("Error initializing sketch: " & ex.Message)
Return
End Try
' Check if the sketch was created successfully
If oSketch Is Nothing Then
MessageBox.Show("Failed to create sketch.")
Return
End If
Dim oOccurrenceList As New List(Of ComponentOccurrence)
Try
oOccurrenceList.Add(oOccurrence)
End If
Next
End Try
'Begin projecting cut edges on sketch
Try
' Start a transaction to project cut edges
Dim oTrans As Transaction = oApp.TransactionManager.StartTransaction(oDoc, "Project Cut Edges")
Dim oControlDef As ControlDefinition = oApp.CommandManager.ControlDefinitions.Item("SketchProjectCutEdgesCmd")
oApp.ActiveDocument.SelectSet.Clear() ' Clear current selection
For Each oOcc In oOccurrenceList
oApp.ActiveDocument.SelectSet.Select(oOcc)
Next
oControlDef.Execute() ' Execute the command
oTrans.End() ' Commit the transaction
MessageBox.Show("Error projecting cut edges: " & ex.Message)
Finally
oApp.CommandManager.StopActiveCommand() ' Ensure no command is left active
End Try
' After projecting the edges, create intersection data and new lines
Dim faceSelected As Face = oFaceProxy.NativeObject
Dim intersectionData As Dictionary(Of SketchLine, List(Of Point2d)) = CreateIntersectPoints(oSketch, faceSelected)
' Begin a new transaction to check for entities on the boundary and delete them
Dim boundaryCheckTrans As Transaction = oApp.TransactionManager.StartTransaction(oDoc, "Check Boundary Entities")
Try
Dim entitiesOnBoundary As New List(Of SketchEntity)
Dim entitiesOutsideBoundary As New List(Of SketchEntity)
' Check each entity in the sketch
For Each skEntity As SketchEntity In oSketch.SketchEntities
Dim startPt As Point = Nothing
Dim endPt As Point = Nothing
' Get the start and end points for SketchLine entities
If TypeOf skEntity Is SketchLine Then
Dim skLine As SketchLine = CType(skEntity, SketchLine)
startPt = oApp.TransientGeometry.CreatePoint(skLine.StartSketchPoint.Geometry.X, skLine.StartSketchPoint.Geometry.Y, 0)
endPt = oApp.TransientGeometry.CreatePoint(skLine.EndSketchPoint.Geometry.X, skLine.EndSketchPoint.Geometry.Y, 0)
ElseIf TypeOf skEntity Is SketchArc Then
Dim skArc As SketchArc = CType(skEntity, SketchArc)
startPt = oApp.TransientGeometry.CreatePoint(skArc.StartSketchPoint.Geometry.X, skArc.StartSketchPoint.Geometry.Y, 0)
endPt = oApp.TransientGeometry.CreatePoint(skArc.EndSketchPoint.Geometry.X, skArc.EndSketchPoint.Geometry.Y, 0)
ElseIf TypeOf skEntity Is SketchCircle Then
' For a circle, both points can be the center as we only check if it's inside the boundary
Dim skCircle As SketchCircle = CType(skEntity, SketchCircle)
startPt = oApp.TransientGeometry.CreatePoint(skCircle.CenterSketchPoint.Geometry.X, skCircle.CenterSketchPoint.Geometry.Y, 0)
endPt = startPt
End If
' Transform points from sketch space to model space if they are not Nothing
If startPt IsNot Nothing AndAlso endPt IsNot Nothing Then
startPt.TransformBy(oSketch.SketchToModelTransform)
endPt.TransformBy(oSketch.SketchToModelTransform)
' Check if the points are on any of the face's edges
Dim onBoundary As Boolean = False
For Each edge As Edge In faceSelected.Edges
Dim minDistStart As Double = oApp.MeasureTools.GetMinimumDistance(startPt, Edge)
Dim minDistEnd As Double = oApp.MeasureTools.GetMinimumDistance(endPt, Edge)
If minDistStart = 0 AndAlso minDistEnd = 0 Then
onBoundary = True
Exit For
End If
Next
' If the entity is on the boundary, add it to the list
If onBoundary Then
entitiesOnBoundary.Add(skEntity)
End If
End If
Next
' Delete all entities that are on the boundary except for projected geometry
For Each entity In entitiesOnBoundary
If Not entity.Construction Then ' Assuming 'Construction' property indicates a projected entity
entity.Delete()
End If
Next
boundaryCheckTrans.End()
MessageBox.Show("An error occurred while checking boundary entities: " & ex.Message)
boundaryCheckTrans.Abort() ' Abort transaction on error
End Try
' Begin a new transaction to create trimmed lines by redrawing them
Dim trimTrans As Transaction = oApp.TransactionManager.StartTransaction(oDoc, "Create Trimmed Lines")
Try
' Attempt to create new lines based on the intersection data
CreateNewLines(oApp, oPartDef, faceSelected, oSketch, intersectionData)
trimTrans.End() ' End the transaction to apply the changes
' MessageBox.Show("Trimmed lines?", "Title")
MessageBox.Show("An error occurred while trimming the lines: " & ex.Message)
trimTrans.Abort() ' Abort transaction on error
Finally
End Try
' Get a reference to the TransientGeometry object which is used to create geometry objects
Dim tg As TransientGeometry = oApp.TransientGeometry
Dim linesToDelete As New List(Of SketchEntity) ' Modify the type to accommodate different types of sketch entities
' Iterate over all sketch entities and delete those outside the face boundary
Dim entityOutsideBoundary As Boolean = False
' Transform points and check boundary
If Not PointIsOnBoundary(faceSelected, startPt) AndAlso Not PointIsOnBoundary(faceSelected, endPt) Then
entityOutsideBoundary = True
End If
End If
' Transform the center point and check boundary
If Not PointIsOnBoundary(faceSelected, startPt) Then
End If
ElseIf TypeOf skEntity Is SketchSpline Then
' Immediately delete the spline without checking its position
Dim skSpline As SketchSpline = CType(skEntity, SketchSpline)
skSpline.Delete()
Continue For ' Skip to next entity after handling spline
End If
' Delete the entity if it is outside the boundary
If entityOutsideBoundary Then
skEntity.Delete()
End If
Next
Dim boundaryCheckPointTrans As Transaction = oApp.TransactionManager.StartTransaction(oDoc, "Check Boundary Entities")
Try
Dim entitiesToDelete As New List(Of SketchEntity)
Dim onBoundaryStart As Boolean = False
Dim onBoundaryEnd As Boolean = False
endPt = startPt ' Circles are centered and so have one relevant point
End If
onBoundaryStart = PointIsOnBoundary(faceSelected, startPt)
onBoundaryEnd = PointIsOnBoundary(faceSelected, endPt)
' If only one of the points is on the boundary and not both, add to delete list
If (onBoundaryStart Xor onBoundaryEnd) OrElse (Not onBoundaryStart And Not onBoundaryEnd) Then
entitiesToDelete.Add(skEntity)
End If
End If
Next
' Delete all entities that are decided to be deleted
For Each entity In entitiesToDelete
entity.Delete()
Next
boundaryCheckPointTrans.End()
End Try
' Start a new transaction for constraint removal
Dim finalTrans As Transaction = oApp.TransactionManager.StartTransaction(oDoc, "Finalize Sketch")
Try
' Activate the sketch for editing
oSketch.Edit()
' Create lists to hold constraints to delete
Dim geoConstraints As New List(Of GeometricConstraint)
Dim dimConstraints As New List(Of DimensionConstraint)
' Add all constraints to the lists
For Each gc As GeometricConstraint In oSketch.GeometricConstraints
geoConstraints.Add(GC)
Next
For Each dc As DimensionConstraint In oSketch.DimensionConstraints
dimConstraints.Add(dc)
Next
' Delete all constraints
For Each gc As GeometricConstraint In geoConstraints
Try
GC.Delete()
' Handle the exception if a constraint cannot be deleted
End Try
Next
For Each dc As DimensionConstraint In dimConstraints
Try
dc.Delete()
End Try
Next
finalTrans.End()
' Finish editing the sketch
oSketch.ExitEdit()
' Handle any errors
MessageBox.Show("An error occurred: " & ex.Message)
finalTrans.Abort()
' Clear the selection
End Try
' Now that all constraints are removed, start a new transaction for applying the fix (ground) constraint
Dim fixTrans As Transaction = oApp.TransactionManager.StartTransaction(oDoc, "Apply Ground Constraint")
Try
' Apply the ground constraint to each entity in the sketch
For Each entity As SketchEntity In oSketch.SketchEntities
' Attempt to apply the ground constraint
Try
oSketch.GeometricConstraints.AddGround(entity)
End Try
Next
fixTrans.End()
' Handle any errors
MessageBox.Show("An error occurred while applying ground constraints: " & ex.Message)
fixTrans.Abort()
Finally
' Clear the selection if necessary
End Try
' Start a new transaction to delete all construction entities (like the face border) and points
Dim deleteConstructionEntitiesAndPointsTrans As Transaction = oApp.TransactionManager.StartTransaction(oDoc, "Delete Construction Entities and Points")
Try
' Iterate over the sketch entities using the reverse loop to avoid index issues
For i2 As Integer = oSketch.SketchEntities.Count - 1 To 0 Step -1
Dim skEntity As SketchEntity = oSketch.SketchEntities.Item(i2 + 1) ' Collections are 1-based in VBA
' Check if the entity is marked as construction geometry and not a point (which we will handle separately)
If Not TypeOf skEntity Is SketchPoint AndAlso skEntity.Construction Then
skEntity.Delete()
End If
Next
' Now handle points separately because they may fail to delete
Dim i3 As Integer = oSketch.SketchPoints.Count
While i3 > 0
Dim skPoint As SketchPoint = oSketch.SketchPoints.Item(i3)
Try
' Attempt to delete the point
skPoint.Delete()
' If there's an error, log it or ignore it, as the point may not be deletable
End Try
i3 -= 1
End While
deleteConstructionEntitiesAndPointsTrans.End() ' Commit the transaction
MessageBox.Show("An error occurred while deleting construction entities and points: " & ex.Message, "Error")
If deleteConstructionEntitiesAndPointsTrans IsNot Nothing Then
deleteConstructionEntitiesAndPointsTrans.Abort() ' Abort transaction on error
End If
End Try
oApp.ActiveDocument.Update2(True)
End Sub
'Functions below
' Function to create intersection points
Public Shared Function CreateIntersectPoints(sk As PlanarSketch, f As Face) As Dictionary(Of SketchLine, List(Of Point2d))
Dim boundaryList As New List(Of SketchEntity)
For Each ege As Edge In f.Edges
Dim se As SketchEntity = sk.AddByProjectingEntity(ege)
se.Construction = True
boundaryList.Add(se)
Next
Dim pointsOnLine As New Dictionary(Of SketchLine, List(Of Point2d))
For Each layoutEnt As SketchEntity In sk.SketchEntities
If boundaryList.Contains(layoutEnt) Then Continue For ' Skip boundary entities
If TypeOf layoutEnt Is SketchLine Then
Dim lineA As SketchLine = CType(layoutEnt, SketchLine)
Dim listOfPoints As New List(Of Point2d)
For Each boundaryEnt As SketchEntity In boundaryList
Dim intersections As ObjectsEnumerator = Nothing
Select Case boundaryEnt.Type
Case ObjectTypeEnum.kSketchLineObject
Dim lineB As SketchLine = CType(boundaryEnt, SketchLine)
intersections = lineA.Geometry.IntersectWithCurve(lineB.Geometry)
Case ObjectTypeEnum.kSketchSplineObject
Dim lineB As SketchSpline = CType(boundaryEnt, SketchSpline)
Case ObjectTypeEnum.kSketchCircleObject
Dim lineB As SketchCircle = CType(boundaryEnt, SketchCircle)
Case ObjectTypeEnum.kSketchArcObject
Dim lineB As SketchArc = CType(boundaryEnt, SketchArc)
End Select
If intersections IsNot Nothing AndAlso intersections.Count > 0 Then
For Each intPoint As Point2d In intersections
listOfPoints.Add(intPoint)
Next
End If
Next
If listOfPoints.Count > 0 AndAlso Not pointsOnLine.ContainsKey(lineA) Then
pointsOnLine.Add(lineA, listOfPoints)
End If
End If
Next
Return pointsOnLine
End Function
' Function to create new lines
Private Shared Sub CreateNewLines(app As Inventor.Application, def As PartComponentDefinition, f As Face, sk As PlanarSketch, linedata As Dictionary(Of SketchLine, List(Of Point2d)))
Dim tg As TransientGeometry = app.TransientGeometry
Try
For Each kvp As KeyValuePair(Of SketchLine, List(Of Point2d)) In linedata
Try
Dim sl As SketchLine = kvp.Key
Dim intersectionPoints As List(Of Point2d) = kvp.Value
intersectionPoints.Sort(Function(a, b) tg.CreatePoint2d(sl.StartSketchPoint.Geometry.X, sl.StartSketchPoint.Geometry.Y).DistanceTo(a).CompareTo(tg.CreatePoint2d(sl.StartSketchPoint.Geometry.X, sl.StartSketchPoint.Geometry.Y).DistanceTo(b)))
Dim allPoints As New List(Of Point2d)(intersectionPoints)
allPoints.Insert(0, sl.StartSketchPoint.Geometry)
allPoints.Add(sl.EndSketchPoint.Geometry)
For i As Integer = 0 To allPoints.Count - 2
Dim point1 As Point2d = allPoints(i)
Dim point2 As Point2d = allPoints(i + 1)
Dim midpoint As Point2d = CalculateMidpoint(app, point1.X, point1.Y, point2.X, point2.Y)
Dim midpoint3D As Point = tg.CreatePoint(midpoint.X, midpoint.Y, 0)
midpoint3D.TransformBy(sk.SketchToModelTransform)
If PointIsOnBoundary(f, midpoint3D) Then
sk.SketchLines.AddByTwoPoints(point1, point2)
End If
Next
sl.Delete()
Catch innerEx As Exception
System.Diagnostics.Debug.WriteLine("Failed processing line: " & innerEx.Message)
End Try
Next
System.Diagnostics.Debug.WriteLine("Error in CreateNewLines: " & ex.Message)
Throw
End Try
End Sub
' Function to calculate midpoint
Public Shared Function CalculateMidpoint(app As Inventor.Application, x1 As Double, y1 As Double, x2 As Double, y2 As Double) As Point2d
Dim midX As Double = (x1 + x2) / 2
Dim midY As Double = (y1 + y2) / 2
Return app.TransientGeometry.CreatePoint2d(midX, midY)
End Function
' Function to check if point is on boundary (defined as Shared)
Public Shared Function PointIsOnBoundary(f As Face, oPoint As Point) As Boolean
Dim closestPoint As Point = f.GetClosestPointTo(oPoint)
Return closestPoint.IsEqualTo(oPoint, 0.0001)
End Function
' Check and delete all splines that might be outside the face boundary
Public Sub CheckAndDeleteSplines(oSketch As PlanarSketch, oApp As Inventor.Application)
Dim splinesToDelete As New List(Of SketchSpline)
' Collect all splines that meet certain criteria
' Potentially add checks here based on properties
' For example, check if the spline is marked as construction geometry
If skSpline.Construction Then
splinesToDelete.Add(skSpline)
End If
End If
Next
' Delete collected splines
For Each spline In splinesToDelete
spline.Delete()
Next
MessageBox.Show("Removed " & splinesToDelete.Count.ToString() & " splines that might be outside the boundary.", "Cleanup Report")
End Sub
