Hi @mark.mohling ,
I had this example on hand. I'll add it here in case it is of interest to you or someone else in the future.
See the attached 2023 files.
I hope this helps.
Curtis
Sub Main
Dim oDrawDoc As DrawingDocument = ThisApplication.ActiveDocument
Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
'get the sheet
Dim oSheet As Sheet
oSheet = oDrawDoc.ActiveSheet
'get base view
Dim oBaseView As DrawingView
oBaseView = oSheet.DrawingViews.Item(1)
Dim DetailViewName As String = "H"
'[ delete view if it already exits
For Each View As DrawingView In oSheet.DrawingViews
'delete view from previous try if it exists
If View.name = DetailViewName Then
Try : View.Delete : Catch : End Try
Next
Dim oViewCenterPoint As Point2d
oViewCenterPoint = oTG.CreatePoint2d(oBaseView.Center.X/1.5, oBaseView.Center.Y*1.5)
'get the first curve segment in the base view
Dim oDrawCurveSegment As DrawingCurveSegment
oDrawCurveSegment = oBaseView.DrawingCurves.Item(1).Segments.Item(1)
'create an intent object from the segment
Dim oGeomIntent As GeometryIntent
oGeomIntent = oSheet.CreateGeometryIntent(oDrawCurveSegment.Parent, oDrawCurveSegment.Parent.EndPoint)
Dim oDetailPlacePoint As Point2d
oDetailPlacePoint = oTG.CreatePoint2d(oBaseView.Center.X + 10, oBaseView.Center.Y)
Dim oDetailView As DrawingView
oDetailView = oSheet.DrawingViews.AddDetailView(oBaseView, oDetailPlacePoint,
DrawingViewStyleEnum.kHiddenLineDrawingViewStyle,
True, oViewCenterPoint, 2, oGeomIntent, 0.125, True, DetailViewName)
End Sub
