How to set Detail Label to left side of Detail View in Inventor idw.
mark.mohling
mark.mohling
I am very new to iLogic and VBA in Inventor .idw.  I have custom layout for my assembly drawings.  I need to change the Detail Label location from the bottom to left side of detail view.  Is there is any I can do to make this happen with iLogic or VBA?  Thanks.
Mark
A.Acheson
Hi @mark.mohling
To start with the drawing view label object has a position property so it can be moved. The next thing is how to access the object this is from the drawing view label property.
This is assuming you have a view allready selected via pick command or drawing view loop. There is a few more pieces to moving but if you search these objects in the forum you can find a sample to work with.
Syntax
DrawingView.Label() As DrawingViewLabel
Syntax
DrawingViewLabel.Position() As Point2d
Regards
Alan
mark.mohling
Thank you for your reply.  I will give the code a try.
Curtis_Waguespack
Hi @mark.mohling ,
I had this example on hand. I'll add it here in case it is of interest to you or someone else in the future.
See the attached 2023 files.
I hope this helps.
Curtis
Sub Main
	Dim oDrawDoc As DrawingDocument = ThisApplication.ActiveDocument
	Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
	'get the sheet
	Dim oSheet As Sheet
	oSheet = oDrawDoc.ActiveSheet
	'get base view
	Dim oBaseView As DrawingView
	oBaseView = oSheet.DrawingViews.Item(1)
	Dim DetailViewName As String = "H"
	'[ delete view if it already exits
	For Each View As DrawingView In oSheet.DrawingViews
		'delete view from previous try if it exists
		If View.name = DetailViewName Then
			Try : View.Delete : Catch : End Try
		End If
	Next
	Dim oViewCenterPoint As Point2d
	oViewCenterPoint =  oTG.CreatePoint2d(oBaseView.Center.X/1.5, oBaseView.Center.Y*1.5)
	'get the first curve segment in the base view
	Dim oDrawCurveSegment As DrawingCurveSegment
	oDrawCurveSegment = oBaseView.DrawingCurves.Item(1).Segments.Item(1)
	'create an intent object from the segment
	Dim oGeomIntent As GeometryIntent
	oGeomIntent = oSheet.CreateGeometryIntent(oDrawCurveSegment.Parent, oDrawCurveSegment.Parent.EndPoint)
	Dim oDetailPlacePoint As Point2d
	oDetailPlacePoint = oTG.CreatePoint2d(oBaseView.Center.X + 10, oBaseView.Center.Y)
	Dim oDetailView As DrawingView
	oDetailView = oSheet.DrawingViews.AddDetailView(oBaseView, oDetailPlacePoint,
	DrawingViewStyleEnum.kHiddenLineDrawingViewStyle,
	True, oViewCenterPoint, 2, oGeomIntent, 0.125, True, DetailViewName)
End Sub
