Hello Inventor Community,
I have following situation:
Assembly1:
I added the attributes over the Ansys Addin (named selection manager)
Part 1: 2 faces for "S_" and 2 faces for "W_"
Part 2: 3 faces for "S_" and 3 faces for "W_"
In the Assembly I want to check if there are parts with AttributeSet Name = "ANSYS_NS_COLLECTION".
If so, create new attribute on assembly level with the same faces as in part level but the item name must be renamed to "S_count" respectively "W_count". ("S_1", W_1"). The AttributeSet Name should remain "ANSYS_NS_COLLECTION".
In the end the Assembly should have 8 attributesets:
Attached is the sample CAD File of the assembly as described here.
What I have so far is to get all the Attributes from the parts. But I dont know how to create new one in the Assembly?
Public Sub AssemblyAttribute()
'check that the active document is an assembly file
If ThisApplication.ActiveDocument.DocumentType <> kAssemblyDocumentObject Then
MsgBox ("Please run this rule from the assembly document file.")
Exit Sub
End If
' Get the active assembly document
Dim oDoc As AssemblyDocument
Set oDoc = ThisApplication.ActiveDocument
Debug.Print "Active Document: " + oDoc.DisplayName
With oDoc
For i = 1 To .ComponentDefinition.Occurrences.Count
Dim oOcc As ComponentOccurrence
Set oOcc = .ComponentDefinition.Occurrences(i)
Debug.Print "NS for Part: " + oOcc.Name
Dim oAttMgr As AttributeManager
Dim oAttsetsEnum As AttributeSetsEnumerator
Set oAttMgr = oOcc.Definition.Document.AttributeManager
Set oAttsetsEnum = oAttMgr.FindAttributeSets("ANSYS_NS_COLLECTION")
Dim oAttSet As AttributeSet
Dim oAtt As Inventor.Attribute
For Each oAttSet In oAttsetsEnum
For Each oAtt In oAttSet
If InStr(oAtt.Name, "S_") Or InStr(oAtt.Name, "W_") Then
Debug.Print oAtt.Name
End If
Next
Next
Next
End With
End Sub
Produces following output:
Active Document: Assembly1.iam
NS for Part: Part2:1
W_
W_
W_
S_
S_
S_
NS for Part: Part2:2
W_
W_
W_
S_
S_
S_
NS for Part: Part1:1
W_
W_
S_
S_
NS for Part: Part1:2
W_
W_
S_
S_
Assembly1:
Exit Sub
End If
With oDoc
End If
Next
Next
Next
End With
End Sub
W_
W_
W_
S_
S_
S_
W_
W_
W_
S_
S_
S_
W_
W_
S_
S_
W_
W_
S_
S_
Solved by Ralf_Krieg. Go to Solution.
Why don't you create iProperties on part level and then write AttributeSet in the assembly ?
to create an attributeSet in an assembly, you need to access it from the occurrence object
ComponentOccurrence.AttributeSets
Hello
A first draw. Suppressed files and virtual components must be ignored.
Dim W_Count As Integer
Dim S_Count As Integer
Exit Sub
End If
With oDoc
Call DeleteAllAttributes(oDoc)
Dim oAssAttrSet As AttributeSet
Set oAssAttrSet = GetAttributeSet(oDoc)
S_Count = 0
W_Count = 0
If oOcc.Suppressed = False Then
If Not oOcc.Definition.Type = kVirtualComponentDefinitionObject Then
If InStr(oAtt.Name, "S_") Then
S_Count = S_Count + 1
ElseIf InStr(oAtt.Name, "W_") Then
W_Count = W_Count + 1
End If
Next
Next
Call AddAttribute(oDoc, "S_" & i, S_Count)
Call AddAttribute(oDoc, "W_" & i, W_Count)
End If
End If
Next
End With
End Sub
Private Sub DeleteAllAttributes(ByVal oDoc As AssemblyDocument)
Dim oAttrEnum As AttributesEnumerator
Dim oAttr As Inventor.Attribute
Dim oAttrSet As AttributeSet
For Each oAttrSet In oDoc.AttributeSets
If oAttrSet.Name = "ANSYS_NS_COLLECTION" Then
Set oAttrEnum = oDoc.AttributeManager.FindAttributes("ANSYS_NS_COLLECTION")
End If
Next
If oAttrEnum Is Nothing Then Exit Sub
For Each oAttr In oAttrEnum
oAttr.Delete
Next
End Sub
Private Sub AddAttribute(ByVal oDoc As AssemblyDocument, ByVal sAttrName As String, ByVal iAttrValue As Integer)
Dim oAttrSetEnum As AttributeSetsEnumerator
Set oAttrSetEnum = oDoc.AttributeManager.FindAttributeSets("ANSYS_NS_COLLECTION")
Set oAttrSet = oAttrSetEnum(1)
Set oAttr = oAttrSet.Add(sAttrName, kIntegerType, iAttrValue)
End Sub
Private Function GetAttributeSet(ByVal oDoc As AssemblyDocument) As AttributeSet
If oAttrSetEnum.Count = 0 Then
Set GetAttributeSet = oDoc.AttributeSets.Add("ANSYS_NS_COLLECTION")
Else
Set GetAttributeSet = oAttrSetEnum(1)
End If
End Function
Hello
Exit Sub
End If
With oDoc
S_Count = 0
W_Count = 0
End If
Next
Next
End If
End If
Next
End With
End Sub
End If
Next
oAttr.Delete
Next
End Sub
End Sub
Else
End If
End Function
As far as I know it's not possible to store faces in Iproperties. I need to know the location of the face which is defined in the part document. I had some issues trying this. Becase the face had already an attribute.
Thank you! How can I add the Face? The code will create attributes but whitout the face.
The attributes in the part document are set to the face.
In the assembly it created assembly attributes but not on the faces. What I need is to create the FaceProxy attributes on the same location as in the part document.
Hello
On one hand you write you need attributes in the assembly with the count (or sum) of faces of type S_ and W_ in each occurrence. On other hand you write that you need attributes on every face proxy. Or do you mean a mix of both, an attribute on every face proxy with the count or sum of type S_x and W_x for each occurrence as value? If so, we need to modify code a bit.
You can "copy" every face attribute to it's face proxy in assembly space wih code below.
'Option Explicit
S_Count = 0
W_Count = 0
Exit Sub
End If
With oDoc
Call CleanAttrSets(oDoc)
'get all faces with attribute
Dim oFaceColl As ObjectCollection
Set oFaceColl = oAttMgr.FindObjects("ANSYS_NS_COLLECTION")
Dim oFace As Face
Dim oFaceProxy As FaceProxy
For Each oFace In oFaceColl
Call oOcc.CreateGeometryProxy(oFace, oFaceProxy)
Set oAttSet = oFace.AttributeSets("ANSYS_NS_COLLECTION")
Call AddAttribute(oFaceProxy, "S_" & S_Count, 1)
Call AddAttribute(oFaceProxy, "W_" & W_Count, 1)
End If
Next
Next
End If
End If
Next
End With
End Sub
Private Sub AddAttribute(ByVal oFaceProxy As FaceProxy, ByVal sAttrName As String, ByVal iAttrValue As Integer)
For Each oAttrSet In oFaceProxy.AttributeSets
If oAttrSet.Name = "ANSYS_NS_COLLECTION" Then Exit For
Next
If oAttrSet Is Nothing Then
Set oAttrSet = oFaceProxy.AttributeSets.Add("ANSYS_NS_COLLECTION")
End If
For Each oAttr In oAttrSet
If oAttr.Name = sAttrName Then Exit For
Next
If oAttr Is Nothing Then
Else
oAttr.Value = oAttr.Value + iAttrValue
End If
End Sub
Else
End If
End Function
Private Sub CleanAttrSets(ByVal oDoc As AssemblyDocument)
Dim oAttrMgr As AttributeManager
Set oAttrMgr = oDoc.AttributeManager
Dim oAttrSetsEnum As AttributeSetsEnumerator
Set oAttrEnum = oAttrMgr.FindAttributes("ANSYS_NS_COLLECTION", "*")
Call oAttr.Delete
Next
Set oAttrSetsEnum = oAttrMgr.FindAttributeSets("ANSYS_NS_COLLECTION")
For Each oAttrSet In oAttrSetsEnum
Call oAttrSet.Delete
Next
End Sub
Hello
'Option Explicit
S_Count = 0
W_Count = 0
Exit Sub
End If
With oDoc
Dim oFace As Face
End If
Next
Next
End If
End If
Next
End With
End Sub
Next
End If
Next
Else
End If
End Sub
Else
End If
End Function
Call oAttr.Delete
Next
Next
End Sub
Perfect! Exactly what I needed🙂
In the meanwhile I tried it by myself but did not get the solution. The error occured when I tried to add the attribute to the attirbute set. Could you explain me what I did wrong?
Exit Sub
End If
S_Count = 0
W_Count = 0
SetName = "ANSYS_NS_COLLECTION"
With oDoc
'Call DeleteAllAttributes(oDoc)
Dim oFace As face
Dim oAttribSets As AttributeSets
Dim oAttribSet As Inventor.AttributeSet
Dim oAttrib As Inventor.Attribute
' Get collection of attributes with SetName "ANSYS_NS_COLLECTION" and Name "S_" or "W_"
Dim oAttCollection_W As Inventor.ObjectCollection
Dim oAttCollection_S As Inventor.ObjectCollection
Set oAttCollection_W = oAttMgr.FindObjects(SetName, "S_")
Set oAttCollection_S = oAttMgr.FindObjects(SetName, "W_")
' Check if there are faces with "W_"
If oAttCollection_W.Count > 0 Then
Debug.Print "W_faces: " + Str(oAttCollection_W.Count)
Name = "W_" + Str(W_Count)
' Iterate over each Face in Collection
For Each oFace In oAttCollection_W
' Create Face Proxy
Set oFaceProxy = Nothing
' get the face proxy attribute sets
Set oAttribSets = oFaceProxy.AttributeSets
' Create attribute set
Set oAttribSet = oFaceProxy.AttributeSets.Add(SetName)
Set oAttrib = oAttribSet.Add(Name, kIntegerType, 1) ' This line did not work ?
Next
End If
End If
End If
Next
End With
End Sub
Exit Sub
End If
S_Count = 0
W_Count = 0
With oDoc
Dim oFace As face
' Create Face Proxy
Next
End If
End If
End If
Next
End With
End Sub
