I have an opportunity to update some files and was going to set the Active Standard for the new to us 3D annotation.
Am i using the right syntax here or is the object not exposed to the API? I notice intellisense does not suggest this when typing.
Dim oApp As Application: Set oApp = ThisApplication
Dim oDoc As PartDocument: Set oDoc = oApp.ActiveDocument
Set oDoc.ActiveAnnotationsStandard = "ISO"
Solved by JelteDeJong. Go to Solution.
this works for me:
Jelte de Jong
Blog: hjalte.nl - github.com
this works for me:
Jelte de Jong
Helps if i don't use 'Set'.
It took me a minute to remind myself but i guess i was browsing the Locals window in VBA.
In the VBA IDE, put a break point somewhere, then browse down from oDoc.
Just dropping the cross-reference link in here to the 'other' recent forum topic which came to the same results as this one.
Wesley Crihfield
(Not an Autodesk Employee)
Wesley Crihfield
