How to project geometry from a base view to a sketch in a drawing
piotrekdoro94
piotrekdoro94
Hi, I have a sheet metal part with a flat pattern. Now I want to create a drawing with a single base view of that flat pattern, then create a sketch on that base view and project all the edges.
Unfortunately, I can't figure out how to project flat pattern edges. I would really appreciate if someone could help me correct my code or provide a simplified example showing how to project a single edge from a part shown in a base view to a sketch, created on the same base view.
Ma part and its flat pattern look like this:
 Here is my code:
Imports Inventor
Imports System.Runtime.InteropServices
Imports System.Text.RegularExpressions
Imports System.Windows.Forms
Imports System.IO
Imports System.Xml.Serialization
Imports System.Security.Cryptography
Imports System.Diagnostics.Contracts
Public Class Form1
    Private Sub Button1_Click(sender As Object, e As EventArgs) Handles Button1.Click
        Try
            Dim InventorApp As Inventor.Application
            Dim oDrawingDoc As DrawingDocument
            InventorApp = Marshal.GetActiveObject("Inventor.Application")
            oDrawingDoc = InventorApp.Documents.Add(DocumentTypeEnum.kDrawingDocumentObject,, True) 'create drawing
            oDrawingDoc.Activate()
            Try
                'MessageBox.Show("Connected To Inventor session")
            Catch ex As Exception
                MessageBox.Show("Failed to connect to inventor session")
            End Try
            oDrawingDoc.Sheets(1).Orientation = PageOrientationTypeEnum.kLandscapePageOrientation 'Change sheet orientation to landscape
            oDrawingDoc.Sheets(1).Size = DrawingSheetSizeEnum.kA3DrawingSheetSize 'Change sheet size to A4
            Dim baseViewOptions As NameValueMap
            baseViewOptions = InventorApp.TransientObjects.CreateNameValueMap() 'Create NameValueMap to use as additional option for view generation
            baseViewOptions.Add("SheetMetalFoldedModel", False) 'Add flat pattern on to additional opiots
            oDrawingDoc.Sheets(1).DrawingViews.AddBaseView(InventorApp.Documents(1), InventorApp.TransientGeometry.CreatePoint2d(), 1, ViewOrientationTypeEnum.kFlatPivot180ViewOrientation, DrawingViewStyleEnum.kHiddenLineRemovedDrawingViewStyle, "Flat pattern",, baseViewOptions) 'Create bbase view with a flat pattern
            Dim baseView As DrawingView
            Dim baseViewHeight As Double
            Dim baseViewWidth As Double
            Dim sheetHeight As Double
            Dim sheetWidth As Double
            baseView = oDrawingDoc.Sheets(1).DrawingViews(1) 'get base view
            baseViewHeight = baseView.Height 'get base view height
            baseViewWidth = baseView.Width 'get base view width
            sheetHeight = oDrawingDoc.Sheets(1).Height 'get sheet height
            sheetWidth = oDrawingDoc.Sheets(1).Width 'get sheet width
            baseView.Position = InventorApp.TransientGeometry.CreatePoint2d(sheetWidth / 2, sheetHeight / 2) 'Move base view to center of sheet
            Dim baseViewReference As PartDocument
            Dim baseViewReferenceCompDef As SheetMetalComponentDefinition
            Dim projectedEdge As Edge
            baseViewReference = baseView.ReferencedDocumentDescriptor.ReferencedDocument
            baseViewReferenceCompDef = baseViewReference.ComponentDefinition
            For Each projectedEdge In baseViewReferenceCompDef.FlatPattern.SurfaceBodies(1).Edges
                Dim drawCurves As DrawingCurvesEnumerator
                drawCurves = baseView.DrawingCurves(projectedEdge)
                Dim drawCurve As DrawingCurve
                For Each drawCurve In drawCurves
                    Dim ent As SketchEntity
                    ent = baseView.Sketches(1).AddByProjectingEntity(drawCurve) '--->!!!Program crashes here on first loop!!!<---
                Next
            Next
            oDrawingDoc.Update()
            MsgBox("Generation failed")
        End Try
    End Sub
End Class
 I've attached the .ipt file and a .zip file with the entire project. In order to run it first open the .ipt file first and then run the code. It finds reference to the ipt file by looking for the first file in active documents collection.
piotrekdoro94
Nevermind, it seems I was overthinking it (and also, I've accidently commented out a line creating the sketch in the first place), I've managed to get the desired effect by using this code:
Imports Inventor
Imports System.IO
Public Class Form1
        Try
            Try
            End Try
            Dim baseViewSketch As DrawingSketch
            baseViewSketch = baseView.Sketches.Add()
            For Each drawCurve In baseView.DrawingCurves
                baseViewSketch.AddByProjectingEntity(drawCurve)
            Next
        End Try
    End Sub
End Class
