How to Get Prefix of Drawing Name?
4 REPLIES 4
BeKirra
219 Views, 4 Replies
For example, a drawing file name = ABCDE12345-111-222.idw/dwg.
How to get the prefix "ABCDE" from the file name in iLogic?
Thanks in advance.
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
4 REPLIES 4
Andrii_Humeniuk
in reply to: BeKirra
Hi @BeKirra . If in your case the prefix is the first 5 characters, then try this code:
Dim oDoc As Document = ThisDoc.Document
Dim sPrefix As String = IO.Path.GetFileNameWithoutExtension(oDoc.FullDocumentName).Substring(0, 5)
MessageBox.Show(sPrefix)
If your name has a different number of letters, you can use this code (it finds the first number):
Public Sub Main()
	Dim sName As String = IO.Path.GetFileNameWithoutExtension(oDoc.FullDocumentName)
	Dim i As Integer = GetFirstNumber(sName)
	MessageBox.Show(sName.Substring(0, i))
End Sub
Private Function GetFirstNumber(ByVal sName As String) As Integer
	For i As Integer = 0 To sName.Length - 1
		If IsNumeric(sName.Chars(i)) Then Return i
	Next i
	Return sName.Length
End Function
Andrii Humeniuk - Leading design engineer
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
BeKirra
in reply to: Andrii_Humeniuk
Sorry, I should give more details.
The number of characters in the drawing name varies through our sales, projects and company standard drawings.
However, the naming format is the same.
"Letters + Numbers" (e.g. LETTERS1234567)
It would definitely help if iLogic code can detect and get all characters before numbers.
Thanks. 🙂
X² + Y² = C²
Curtis_Waguespack
@BeKirra
Maybe something like this example.
I hope this helps.
Curtis
sName = "ABCDE12345-111-222.idw"
sArray = Split(sName, "-") 'split string using dash
sPrefix = sArray(0) 'get first string in array
'assemble string using only letters in string
Dim LeffterPrefix As New System.Text.StringBuilder
For Each chr As Char In sPrefix
	If Char.IsLetter(Chr) Then
		LeffterPrefix.Append(Chr)
	End If
Next
'convert stringbuilder to string
sPrefix = LeffterPrefix.ToString
MsgBox(sPrefix,, sName)
BeKirra
in reply to: Curtis_Waguespack
Thanks to @Andrii_Humeniuk
I insert your 2nd code to mine as a module. but it doesn't work.
The message is about the "Public sub" function.
It may be caused by the variable name conflict.
I need to dig into it.
It works when saving your code as an file.
Also thanks to @Curtis_Waguespack
Your code works straightforward.
X² + Y² = C²
Technology Administrators
