Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
How to Get data of all planes of a part?
2 REPLIES 2
354 Views, 2 Replies
I create a part and want to get the normal vector and one point of every plane of the part.
I don't know how to use the function "GetPlaneData()".
The code:
Dim oApp As Inventor.Application
Set oApp = ThisApplication
Dim oFace As Face
Dim oPartDef As PartComponentDefinition
Set oPartDef = oApp.ActiveDocument.ComponentDefinition
Dim oTG As TransientGeometry
Set oTG = oApp.TransientGeometry
For Each oFace In oPartDef.SurfaceBodies(1).Faces
Select Case oFace.SurfaceType
Case kPlaneSurface
Dim oPoint As Point
oPoint = ------------------------what should be here?
Dim oNormal As Vector
oNormal = oFace.Geometry.Normal
Next
thanks!
lancheng
The code:
Dim oFace As Face
Case kPlaneSurface
Dim oPoint As Point
Next
thanks!
lancheng
2 REPLIES 2
Here's a version of your program that gets the point and vector of each
planar face.
Dim oFace As Face
If oFace.SurfaceType = kPlaneSurface Then
Dim oPlane As Plane
Set oPlane = oFace.Geometry
Dim oPoint As Point
Set oPoint = oPlane.RootPoint
Dim oNormal As UnitVector
Set oNormal = oPlane.Normal
Next
Brian Ekins
Autodesk Inventor API
planar face.
Dim oFace As Face
Dim oPlane As Plane
Dim oPoint As Point
Next
Brian Ekins
Thanks~~~~~
Thanks~~~~~
