How to get Access to Variable Project file
4 REPLIES 4
andreas_schleif
172 Views, 4 Replies
how do I get access to the variable owner and release ID of the project file ( .ipj ) in such a way that I can display it on a drawing, for example?
I would like to make the variables available via the iProperties.
Many thanks for your support
Andreas
4 REPLIES 4
vpeuvion
in reply to: andreas_schleif
This may be able to help you. It's not recent, but still works on my 2023 version.
https://inventortrenches.blogspot.com/2012/07/ilogic-and-inventor-project-file.html
Hope this will help you. Vincent.
nstevelmans
in reply to: vpeuvion
Hi, Try this in a drawing
Dim DesignProject = ThisApplication.DesignProjectManager.ActiveDesignProject
Dim oOwner As String = DesignProject.Owner
Dim oId As String = DesignProject.ReleaseId
iProperties.Value("Custom", "Owner") = oOwner
iProperties.Value("Custom", "releaseID") = oId
'MsgBox(oOwner)
'MsgBox(oId)
If a response answers your question, please use  ACCEPT SOLUTION  to assist other users later.
Also be generous with Likes!  Thank you and enjoy!
Stakin
Thisapplication.DesignProjectManager.Projects.ActiveProject
Thank you
Technology Administrators
