Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
How to edit an exisitng sketch using the API
3 REPLIES 3
gert-leonvanlier
569 Views, 3 Replies
gert-leonvanlier
I want to edit an exisitng sketch called "SketchSupportPositions". I have found several examples on how to create a new sketch, but that is not what I need. Can anyone give me an example on how to get my existing sketch?
Labels (2)
3 REPLIES 3
dutt.thakar
@gert-leonvanlier
Try this to reach in edit state of the sketch
Dim oDef As PartComponentDefinition = ThisApplication.ActiveDocument.ComponentDefinition
		Dim oSketch As PlanarSketch = oDef.Sketches("SketchSupportPositions")
oSketch.Edit
To exit the edit state of a sketch
oSketch.ExitEdit
Hope this will be helpful.
If this answer has solved your problem please ACCEPT SOLUTION and hit like if you found it helpful..!
Dutt Thakar
LinkedIn
@gert-leonvanlier
oSketch.Edit
oSketch.ExitEdit
Dutt Thakar
LinkedIn
bhavik4244
@gert-leonvanlier
This could help you,
Dim oPartDoc As PartDocument
Dim oTG As TransientGeometry
oPartDoc = ThisApplication.ActiveDocument
oTG = ThisApplication.TransientGeometry
oSketch = oPartDoc.ComponentDefinition.Sketches(1)
MessageBox.Show(oSketch.Name, "Title")
oSketch.Edit
Bhavik Suthar
@gert-leonvanlier
oSketch.Edit
Bhavik Suthar
gert-leonvanlier
@dutt.thakar wrote:
@gert-leonvanlier
oSketch.Edit
oSketch.ExitEdit
This works! Thank you.
@dutt.thakar wrote:
@gert-leonvanlier
oSketch.Edit
oSketch.ExitEdit
