How to dimension Edge with Centerline? I tried as below but not generating.
Edge Edge1;
object obj1;
Inventor.ObjectCollection Obj;
Obj = invApp.TransientObjects.CreateObjectCollection();
Obj = oPartDoc.AttributeManager.FindObjects("iLogicEntityNameSet", "iLogicEntityName", EdgeName1);
Edge1 = (Edge)Obj[1];
Inventor.Point2d Point1, Point2;
DrawingCurvesEnumerator DrgCurveEnum;
DrawingCurve DrgCurve1 = null;
GeometryIntent wInt1 = null, wInt2 = null;
try
if (boolAssembly == true)
CompOcc.CreateGeometryProxy(Edge1, out obj1);
DrgCurveEnum = CurrView.DrawingCurves[obj1];
DrgCurve1 = DrgCurveEnum[1];
else
DrgCurveEnum = CurrView.DrawingCurves[Edge1];
catch (Exception ex)
MessageBox.Show(ex.Message);
Inventor.Point2d InsPt;
InsPt = invApp.TransientGeometry.CreatePoint2d(CurrView.Position.X + 1, CurrView.Position.Y + 1);
GeneralDimensions oGeneralDims;
oGeneralDims = oSheet.DrawingDimensions.GeneralDimensions;
GeneralDimension oDim;
oDim = (GeneralDimension)oGeneralDims.AddLinear(InsPt, oSheet.CreateGeometryIntent(DrgCurve1), Clines, DimType);
Try this simple code for beginning. ThisApplication is instance of Inventor.Application
Selected curve and centerline must belong to one drawing view
var pick = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingCurveSegmentFilter, "Select drawing curve");
var drawingCurve = (pick as DrawingCurveSegment)?.Parent;
pick = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingCenterlineFilter, "Select centerline");
var centerline = pick as Centerline;
if (drawingCurve == null || centerline == null)
MessageBox.Show("Invalid selection");
return;
var drawingView = drawingCurve.Parent;
var sheet = drawingView.Parent;
var textOrigin = drawingView.Position;
var intentOne = sheet.CreateGeometryIntent(drawingCurve);
var intentTwo = sheet.CreateGeometryIntent(centerline);
var linearGeneralDimension = sheet.DrawingDimensions.GeneralDimensions.AddLinear(textOrigin, intentOne, intentTwo);
