All,
Good morning! I've ventured into the exciting world of iLogic once again and have a question on accessing the BOM Qty columns of a Parts List. I believe the entity that I'm looking for is the 'kBOMQuantityObject', but I'm not sure. I've been able to identify the "QTY" columns in the Parts List, but I'm using text string comparisons to get there. It works, but I'm missing the "Base Qty", "Item Qty" and "Unit Qty" for some reason...
Ultimately my goal is to replace 0 quantity items with a "-", but don't want to do that for every potential column, just for quantity columns, so I'm leery about setting every 0 value to a "-". This is why I'm searching for a reliable way to isolate the quantity columns.
I've made a video to help illustrate this as well. Much thanks to @Anonymous for the code to cycle through the Parts List rows and columns.
'Define the necessary objects Dim oDrawDoc As DrawingDocument = ThisDoc.Document Dim oSheet As Sheet = oDrawDoc.ActiveSheet Dim oPartsList As PartsList = oSheet.PartsLists.Item(1) Dim oPLColumn As PartsListColumn Dim oPLRow As PartsListRow Dim oPLCell As PartsListCell 'iterate through each row of the parts list For i = 1 To oPartsList.PartsListRows.Count oPLRow = oPartsList.PartsListRows.Item(i) 'look at each column in the row For j = 1 To oPartsList.PartsListColumns.Count oPLColumn = oPartsList.PartsListColumns.Item(j) oPLCell = oPLRow.Item(j) 'Check to see if the column title contains the letters "qty", "True" indicates the case doesn't matter If String.Compare(Left(oPLColumn.Title, 3), "qty", True) = 0 Or String.Compare(Mid(oPLColumn.Title, 5, 3), "qty", True) = 0 Then ' If oPLCell.Type = kBOMQuantityObject Then 'Check to see if the cell has not been overriden and is set to 0, if so, replace the value with a "-" Try If oPLCell.Static = False And oPLCell.Value = 0 Then oPLCell.Value = "-" Else If oPLCell.Static = True Temp_Val = oPLCell.Value oPLCell.Static = False If oPLCell.Value = 0 Then oPLCell.Value = "-" Else oPLCell.Value = Temp_Val End If End If Catch End Try End If Next Next iLogicVb.UpdateWhenDone = True
Solved by petestrycharske. Go to Solution.
Solved by WCrihfield. Go to Solution.
Solved by A.Acheson. Go to Solution.
Hi @petestrycharske. Since it looks like you may know your way around in iLogic and PartsLists for the most part, here is a bit of iLogic code that should point you in the right direction for identifying those columns and cells within your parts lists. The main point I'm showing within is how to use the column's PropertyType and check it against the PropertyTypeEnum variants to determine what type of data the column was designed to show, then record that column for use when looping through the cells of each row, so you know where that data will be in those rows. Of course, if you have not designed those columns into your parts list, you will not find them this way though, but you could probably add them, if not found, and needed.
oDDoc = ThisDrawing.Document
oSheet = oDDoc.ActiveSheet
oPList = oSheet.PartsLists.Item(1)
Dim oCol, oBaseQtyCol, oItemQtyCol, oUnitQtyCol As PartsListColumn
'find columns for quantities
For Each oCol In oPList.PartsListColumns
If oCol.PropertyType = PropertyTypeEnum.kBaseQuantityPartsListProperty Then
oBaseQtyCol = oCol
ElseIf oCol.PropertyType = PropertyTypeEnum.kUnitQuantityPartsListProperty Then
oUnitQtyCol = oCol
ElseIf oCol.PropertyType = PropertyTypeEnum.kItemQuantityPartsListProperty Then
oItemQtyCol = oCol
End If
Next
Dim oBaseQtyVal, oItemQtyVal, oUnitQtyVal As String
For Each oRow As PartsListRow In oPList.PartsListRows
'get Cell values corresponding to identified columns
oBaseQtyVal = oRow.Item(oBaseQtyCol).Value
oItemQtyVal = oRow.Item(oItemQtyCol).Value
oUnitQtyVal = oRow.Item(oUnitQtyCol).Value
Next
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click (LIKE or KUDOS) 👍.
If you want and have time, I would appreciate your Vote(s) for My IDEAS :light_bulb: or you can Explore My CONTRIBUTIONS
Wesley Crihfield
(Not an Autodesk Employee)
@WCrihfield, thank you so much! I realized after looking at your code, I was using "Type", not "PropertyType", so thanks for clearing that up for me. However, now I've run into a new set of challenges. The code, as written, only changes the last configuration of the iAssembly PartsList, so I was wondering if you had any tips or links for creating an array. Below is a video link of what I'm seeing...
https://knowledge.autodesk.com/community/screencast/ff7c3de3-8f66-43f1-8754-e6c619b147b9
Appreciate all the help and have a most blessed night!
Peace,
Pete
Would it be easier to identify the column index by what is contained in the column title?
oPLColumn.Title.Contains("Qty")
Place this in an if statement and this should confine the search to the cells in those columns.
It isn't the object method you were looking at but rather would be just looking purely at what the user sees in the table.
Hi @petestrycharske. I believe I understand the situation now. However, in this situation, I believe that working with List objects to get the multiple columns of the same type may be an easier option than attempting to use Array objects, but that is mostly personal preference. With a List, I don't have to specify collection size ahead of time, and it will be 1 based, instead of 0 based, which is just more natural. I altered my iLogic code a bit to accommodate that unique situation. So now I have created 3 List(Of PartsListColumn) objects just ahead of looping through the columns. Each List is for one type of column, which there may be multiple of. And within the loop, if the column is the specific type, it gets added to the corresponding List object. Then later when it is looping through the rows, it now does a secondary loop through those lists of columns, as it does the final checks and changes. See if this idea works better for you.
Dim oBaseQtyCols, oItemQtyCols, oUnitQtyCols As New List(Of PartsListColumn)
For Each oCol As PartsListColumn In oPList.PartsListColumns
oBaseQtyCols.Add(oCol)
oUnitQtyCols.Add(oCol)
oItemQtyCols.Add(oCol)
End If
Next
'if you really need an Array, instead of a List, just convert it like this
'oBQtyCols = oBaseQtyCols.ToArray
'List is 1 based (first Item index is 1), Array is 0 based (first Item index is 0)
If oBaseQtyCols.Count > 0 Then
For X As Integer = 1 To oBaseQtyCols.Count
If Not oRow.Item(oBaseQtyCols.Item(X)).Static And _
oRow.Item(oBaseQtyCols.Item(X)).Value = "0" Then
oRow.Item(oBaseQtyCols.Item(X)).Value = "-"
End If
Next
End If
If oUnitQtyCols.Count > 0 Then
For X As Integer = 1 To oUnitQtyCols.Count
If Not oRow.Item(oUnitQtyCols.Item(X)).Static And _
oRow.Item(oUnitQtyCols.Item(X)).Value = "0" Then
oRow.Item(oUnitQtyCols.Item(X)).Value = "-"
End If
Next
End If
If oItemQtyCols.Count > 0 Then
For X As Integer = 1 To oItemQtyCols.Count
If Not oRow.Item(oItemQtyCols.Item(X)).Static And _
oRow.Item(oItemQtyCols .Item(X)).Value = "0" Then
oRow.Item(oItemQtyCols.Item(X)).Value = "-"
End If
Next
End If
Next
Wesley Crihfield
@A.Acheson, YES!!! This is actually what I wanted to do in the beginning, but for some reason I couldn't find the "CONTAINS" option... Is that contains case sensitive? It doesn't look like it is, but I'm not finding any information on it in the iLogic help... Is this just a general VB.Net thing?
Anyway, thanks for this tip, as this got me what I wanted and make the code a bit shorter. Have an awesome and most blessed day!
Peace,
Pete
@WCrihfield, thanks for the tip on lists! After playing with it a bit, I think you do have to treat it like an array counting from Item "0". I modified my line of code below to incorporate your changes (I'll post the full code below). It works beautifully and am confident it won't modify any columns unintentionally! Appreciate the help and have a most blessed day!
Peace,
Pete
For Each oPLRow In oPartsList.PartsListRows If oQtyCols.Count > 0 Then For i = 0 To oQtyCols.Count - 1 Cell_Checker(oPLRow.Item(oQtyCols.Item(i))) Next End If
Here is the code that will ONLY impact BOM quantity columns, so it won't inadvertently update any other columns that may contain the characters "qty". Thanks again @WCrihfield!!!
Sub Main 'Define the necessary objects Dim oDrawDoc As DrawingDocument = ThisDoc.Document Dim oSheet As Sheet = oDrawDoc.ActiveSheet Dim oPartsList As PartsList = oSheet.PartsLists.Item(1) Dim oPLColumn As PartsListColumn Dim oPLRow As PartsListRow Dim oPLCell As PartsListCell Dim oQtyCols As New List (Of PartsListColumn) Dim oBaseQtyCols As New List (Of PartsListColumn) Dim oItemQtyCols As New List (Of PartsListColumn) Dim oUnitQtyCols As New List (Of PartsListColumn) 'Iterate through every column in the parts list, identify it as a particular BOM 'column and then add it to a list for each BOM type For Each oPLColumn In oPartsList.PartsListColumns If oPLColumn.PropertyType = kQuantityPartsListProperty Then oQtyCols.Add(oPLColumn) Else If oPLColumn.PropertyType = kBaseQuantityPartsListProperty Then oBaseQtyCols.Add(oPLColumn) Else If oPLColumn.PropertyType = kItemQuantityPartsListProperty Then oItemQtyCols.Add(oPLColumn) Else If oPLColumn.PropertyType = kUnitQuantityPartsListProperty Then oUnitQtyCols.Add(oPLColumn) End If Next 'Cycle through each row of the parts list and modify only the BOM columns 'using the list from above and the Cell_Checker subroutine For Each oPLRow In oPartsList.PartsListRows If oQtyCols.Count > 0 Then For i = 0 To oQtyCols.Count - 1 Cell_Checker(oPLRow.Item(oQtyCols.Item(i))) Next End If If oBaseQtyCols.Count > 0 Then For i = 0 To oBaseQtyCols.Count - 1 Cell_Checker(oPLRow.Item(oBaseQtyCols.Item(i))) Next End If If oItemQtyCols.Count > 0 Then For i = 0 To oItemQtyCols.Count - 1 Cell_Checker(oPLRow.Item(oItemQtyCols.Item(i))) Next End If If oUnitQtyCols.Count > 0 Then For i = 0 To oUnitQtyCols.Count - 1 Cell_Checker(oPLRow.Item(oUnitQtyCols.Item(i))) Next End If Next iLogicVb.UpdateWhenDone = True End Sub Public Sub Cell_Checker (oPLCell As PartsListCell) 'Check to see if the cell has not been overriden and is set to 0, if so, replace the value with a "-" Try If oPLCell.Static = False And oPLCell.Value = 0 Then oPLCell.Value = "-" 'Check to see if the underlying assembly quantity is 0 for Static cells and make the change to "-" 'if the assembly quantity is 0. Otherwise, leave the overriden value in place Else If oPLCell.Static = True Temp_Val = oPLCell.Value oPLCell.Static = False If oPLCell.Value = 0 Then oPLCell.Value = "-" Else oPLCell.Value = Temp_Val End If End If Catch End Try End Sub
Here is the code that will impact ANY column that contains the characters "qty". Thanks again @A.Acheson!!!
'Define the necessary objects Dim oDrawDoc As DrawingDocument = ThisDoc.Document Dim oSheet As Sheet = oDrawDoc.ActiveSheet Dim oPartsList As PartsList = oSheet.PartsLists.Item(1) Dim oPLColumn As PartsListColumn Dim oPLRow As PartsListRow Dim oPLCell As PartsListCell Dim oQtyCols As New List (Of PartsListColumn) Dim oBaseQtyCols As New List(Of PartsListColumn) Dim oItemQtyCols As New List (Of PartsListColumn) Dim oUnitQtyCols As New List (Of PartsListColumn) 'iterate through each row of the parts list For i = 1 To oPartsList.PartsListRows.Count oPLRow = oPartsList.PartsListRows.Item(i) 'look at each column in the row For j = 1 To oPartsList.PartsListColumns.Count oPLColumn = oPartsList.PartsListColumns.Item(j) oPLCell = oPLRow.Item(j) 'Check to see if the column title contains the letters "qty" If oPLColumn.Title.Contains("Qty") Then Try 'Check to see if the cell has not been overriden and is set to 0, if so, 'replace the value With a "-" If oPLCell.Static = False And oPLCell.Value = 0 Then oPLCell.Value = "-" 'Check to see if the underlying assembly quantity is 0 for Static cells and make the change 'to "-" if the assembly quantity is 0. Otherwise, leave the overriden value in place Else If oPLCell.Static = True Temp_Val = oPLCell.Value oPLCell.Static = False If oPLCell.Value = 0 Then oPLCell.Value = "-" Else oPLCell.Value = Temp_Val End If End If Catch End Try End If Next Next iLogicVb.UpdateWhenDone = True
This looks to be a VB.NET method. Once you have a string just type "." and the dropdown will bring up the list of methods available.
https://docs.microsoft.com/en-us/dotnet/api/system.string.contains?view=net-6.0
The equivalent in VBA is
InStr([ start ], string1, string2, [ compare ])
https://docs.microsoft.com/en-us/office/vba/language/reference/user-interface-help/instr-function
Actually I likely have never tried to use this in VBA so I learned something in checking out the origins. As regards case sensitivity I believe both VB.NET and VBA are not case sensitive but I do prefer to keep things uniform regardless.
Glad I could help.
If I'm correct in my inspection of the two resulting codes, I believe you could greatly condense the code and maintain its current functionality. Since you are doing the same end task on every cell that is within any of those quantity type columns, why not just all the columns to the same single List object, using either a Select Case...Case block or If...ElseIf block, then using a single loop later for just that one List object, instead of different loops for 4 different lists. If we do this, we could cut the code down to at least 2/3 its original size.
Sort of like this:
Sub Main
'Iterate through every column in the parts list, identify it as a Qty column
'then add it to a list
If oPLColumn.PropertyType = kQuantityPartsListProperty Or _
oPLColumn.PropertyType = kBaseQuantityPartsListProperty Or _
oPLColumn.PropertyType = kItemQuantityPartsListProperty Or _
End If
Next
Next
End If
Next
End Sub
Try
oPLCell.Value = "-"
oPLCell.Value = "-"
Else
End If
End If
Catch
End Try
End Sub
Wesley Crihfield
Better yet. If we go with just checking if the column title contains "Qty", then we can condense it down even further, while still making use of the single List object and still using For Each loops instead of those pesky For I loops. Here is a fairly condensed version using that route.
Sub Main
Dim oQtyCols As New List(Of PartsListColumn)
oQtyCols.AddRange(oPartsList.PartsListColumns.OfType(Of Inventor.PartsListColumn).Where(Function(c) c.Title.Contains("Qty")))
If oQtyCols.Count = 0 Then Exit Sub
For Each oPLRow As PartsListRow In oPartsList.PartsListRows
For Each oQtyCol In oQtyCols
oCell = oPLRow.Item(oQtyCol)
Try
If oCell.Static = False And oCell.Value = "0" Then 'the value is a String
oPLRow.Item(oQtyCol).Value = "-"
Else If oCell.Static = True
Temp_Val = oCell.Value
If oCell.Value = 0 Then
oCell.Value = "-"
Else
oCell.Value = Temp_Val
End If
End If
Catch
End Try
Next
Next
End Sub
Wesley Crihfield
