How to delete parts body name that was added?
Chirpyboy2060647
Chirpyboy2060647
Currently running a rule that I found through the forums to add a prefix text and suffix to the solid body's. Im not great at writing out code minus some iLogic stuff I can figure out. Was looking for a way that could search for the added text to the solid bodies, and delete it.
So say the bodies list was like:
LE
RE
Backer
Nailer
Door
Run the code below and it say something like
CB_LE_5523
CB_RE_5523
CB_Backer_5523
CB_Nailer_5523
CB_Door_5523
So would need something that would delete the added text.
in case others might want that code to rename as well:
Dim oDoc As PartDocument = ThisDoc.Document
Dim oDef As PartComponentDefinition = oDoc.ComponentDefinition
Dim oSolid As SurfaceBody
Dim oSolidName As String
Dim oPrefix As String = InputBox("Provide a prefix for each solid. If error, keep undoing untill names are back to original:", "Solid Body Prefix","")
Dim oSuffix As String = InputBox("Provide a suffix for each solid. If error, keep undoing untill names are back to original:", "Solid Body Suffix","")
'iterate through all solids and rename if default
For Each oSolid In oDef.SurfaceBodies
    oSolidName = oSolid.Name
    oSolid.Name = oPrefix & oSolidName & oSuffix
Next oSolid
A.Acheson
Have a look at the string functions of contains and replace.
Dim oPrefix As String = InputBox("Provide a prefix for each solid. If error, keep undoing untill names are back to original:", "Solid Body Prefix","CB_")
Dim oSuffix As String = InputBox("Provide a suffix for each solid. If error, keep undoing untill names are back to original:", "Solid Body Suffix","_5523")
	If oSolidName.Contains(oPrefix) Then
	   oSolidName = oSolidName.Replace(oPrefix, "")
	If oSolidName.Contains(oSuffix) Then
	   oSolidName = oSolidName.Replace(oSuffix, "")
	oSolid.Name = oSolidName
Next oSolid
Regards
Alan
Chirpyboy2060647
Awesome and thank you! Finally getting back into Inventor with new job and exploring ways to make things less tedious. Appreciate it!
