Hi All, i am stuck with this issue since long need your help.
I have two slots where it has collection of 12 faces. i need to check whether the two slots are aligned at 90deg forming "L" shape arrangement.
So i thought to check with any of the faces in slot whether they overlap.
i tried checking with face vertices but unable to get exact overlap.
please share solution how can i check whether two faces overlap each other.
Thanks in advance.
Hello
It's difficult to imagine the exact situation. Can you post screenshots of possible positions of the two slots or a simplified demo assembly?
A simple way would be just to check the angle between two faces of the slots. If you assign the name "SideFace" to one face of the slot and the two occurrences in the assembly are named Part:1 and Part:2, the iLogic below can return the angle.
Sub Main()
Dim oAssDoc As AssemblyDocument = ThisDoc.Document
Dim fp1 As FaceProxy
Dim fp2 As FaceProxy
For Each oOcc As ComponentOccurrence In oAssDoc.ComponentDefinition.Occurrences
Select Case oOcc.Name
Case "Part:1" : fp1 =GetProxy(oOcc)
Case "Part:2" : fp2 =GetProxy(oOcc)
End Select
Next
Dim oAngle As Double = 180/PI * ThisApplication.MeasureTools.GetAngle(fp1, fp2)
MsgBox(oAngle & "°")
End Sub
Private Function GetProxy(ByVal oOcc As ComponentOccurrence) As FaceProxy
Dim iLogicAuto = iLogicVb.Automation
Dim namedEntities = iLogicAuto.GetNamedEntities(oOcc.Definition.Document )
Dim o As Object
If namedEntities.NameExists("SideFace") Then
o = namedEntities.FindEntity("Sideface")
f=TryCast(o,Face)
End If
If f Is Nothing Then Return Nothing
oOcc.CreateGeometryProxy(f, GetProxy)
End Function
