Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
How to check exactly the Block that used in the Solid?
2 REPLIES 2
ngnam1988
301 Views, 2 Replies
Dears,
Is there any way can check exactly the Block that only used in the solid? Normally I used Block for Extrude feature,
Tags (3)
2 REPLIES 2
WCrihfield
in reply to: ngnam1988
Hi @ngnam1988.  I am not sure if what I think you are asking about is possible to determine by code with that little information, and if it was possible, it would likely require a super long, and very complicated rule.  Here is an exploratory rule you can play around with though.  It mostly just writes related data to the iLogic Log window for you.  It first makes sure we are dealing with a Part, then makes sure it has some bodies, then gets the first body.  It reports the body name to the log.  Then it gets which generic PartFeature created it, and checks if it was an Extrusion type feature.  If so, it reports that feature name to the Log.  Then it gets the Profile used to create it, then gets its parent Sketch, and reports the name of the Sketch to the Log.  Then it searches for first level SketchBlock objects within that sketch, and writes their names and count to the Log.  Then it looks for second level (deeper) SketchBlock objects under the first level ones, and writes their names and count to the Log.  And if any second level blocks were found, a message shows the name of the first one.  But there is no guarantee that the one being reported is the only SketchBlock being used to create that body.
Sub Main
	If ThisDoc.Document.DocumentType <> DocumentTypeEnum.kPartDocumentObject Then Exit Sub
	Dim oPDoc As PartDocument = ThisDoc.Document
	Dim oPDef As PartComponentDefinition = oPDoc.ComponentDefinition
	Dim oBodies As SurfaceBodies = oPDef.SurfaceBodies
	If oBodies.Count = 0 Then Exit Sub
	Dim oBody As SurfaceBody = oBodies.Item(1)
	If oBody.IsTransient Then Exit Sub
	Logger.Info("Body Name = " & oBody.Name)
	Dim oFeat As PartFeature = oBody.CreatedByFeature
	Dim oFirstLevelBlocks As New List(Of Inventor.SketchBlock)
	Dim oSecondLevelBlocks As New List(Of Inventor.SketchBlock)
	If oFeat.Type = ObjectTypeEnum.kExtrudeFeatureObject Then
		Dim oExtFeat As ExtrudeFeature = oFeat
		Logger.Info("Extrude Feature Name = " & oExtFeat.Name)
		Dim oProfile As Inventor.Profile = oExtFeat.Definition.Profile
		Dim oSketch As Inventor.Sketch = oProfile.Parent
		Logger.Info("Sketch Name = " & oSketch.Name)
		For Each oEnt As SketchEntity In oSketch.SketchEntities
			Dim oBlock1 As SketchBlock = oEnt.ContainingSketchBlock
			If oBlock1 IsNot Nothing AndAlso oFirstLevelBlocks.Contains(oBlock1) = False Then
				oFirstLevelBlocks.Add(oBlock1)
				Logger.Info("First Level SketchBlock Name = " & oBlock1.Name)
			End If
		Next 'oEnt
		Logger.Info("First Level SketchBlocks Count = " & oFirstLevelBlocks.Count)
		If oFirstLevelBlocks.Count = 0 Then Exit Sub
		For Each oFLBlock In oFirstLevelBlocks
			If oFLBlock.ChildBlocks.Count = 0 Then Continue For
			For Each oSLBlock As SketchBlock In oFLBlock.ChildBlocks
				If oSecondLevelBlocks.Contains(oSLBlock) = False Then
					oSecondLevelBlocks.Add(oSLBlock)
					Logger.Info("Second Level SketchBlock Name = " & oSLBlock.Name)
				End If
			Next 'oSLBlock
		Next 'oFLBlock
		Logger.Info("Second Level SketchBlocks Count = " & oSecondLevelBlocks.Count)
	End If 'feature type check
	If oSecondLevelBlocks.Count > 0 Then
		MsgBox("The name of the first SketchBlock in the second level of SketchBlocks is " & _
		oSecondLevelBlocks.First.Name,,"")
	End If
End Sub
Wesley Crihfield
(Not an Autodesk Employee)
ngnam1988
in reply to: WCrihfield
Thanks for your code @WCrihfield,
It's not return correct my question but it's very helpful. I'm trying understand, and working with some other idea. Thanks,
