how to change weld size in weld symbol by ilogic
sameer_marat
sameer_marat
Community Visitor
Community Visitor
JelteDeJong
Try the following iLogic rule:
Dim obj = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAllEntitiesFilter, "Select a weld symbol")
If (TypeOf obj IsNot DrawingWeldingSymbol) Then
    MsgBox("You did not select a welding symbol")
    Return
End If
Dim symbol As DrawingWeldingSymbol = obj
Dim def As DrawingWeldingSymbolDefinition = symbol.Definitions.Item(1)
Dim symbolDef1 = def.WeldSymbolOne
Dim symbolDef2 = def.WeldSymbolTwo
symbolDef1.Prefix = "Prefix 1"
symbolDef1.Leg1 = "Leg 1.1"
symbolDef1.Leg2 = "Leg 1.2"
symbolDef1.WeldSymbolType = WeldSymbolTypeEnum.kFilletWeldSymbolType
symbolDef1.Length = "Length 1"
symbolDef1.Pitch = "Pitch 1"
symbolDef2.Prefix = "Prefix 2"
symbolDef2.Leg1 = "Leg 2.1"
symbolDef2.Leg2 = "Leg 2.2"
symbolDef2.WeldSymbolType = WeldSymbolTypeEnum.kFilletWeldSymbolType
symbolDef2.Length = "Length 2"
symbolDef2.Pitch = "Pitch 2"
Jelte de Jong
Blog: hjalte.nl - github.com
sameer_marat
Community Visitor
Community Visitor
I need welding size to be changed in specific welding symbol
