Hello Guys,
In examples I found sample code where is shown how to split 1st part body by 2nd part body if they are in assembly. My task is inverse. I need to join 1st part body with 2nd part body. In Samples I found code where two part bodies are join as TransientBreps and new body is writen to 3rd part file. For me is important this Join to have as feature in 1st part body. So I wrote such code:
Sub DoJoin()
Dim oAsmDoc As AssemblyDocument
Set oAsmDoc = ThisApplication.ActiveDocument
Dim oOcc1 As ComponentOccurrence
Set oOcc1 = oAsmDoc.ComponentDefinition.Occurrences(1)
Dim oOcc2 As ComponentOccurrence
Set oOcc2 = oAsmDoc.ComponentDefinition.Occurrences(2)
Dim oPartDoc As PartDocument
Dim oPartDef As PartComponentDefinition
Set oPartDoc = oOcc2.Definition.Document
Set oPartDef = oPartDoc.ComponentDefinition
Dim oTransientBRep As TransientBRep
Set oTransientBRep = ThisApplication.TransientBRep
Dim oBody1 As SurfaceBody
Set oBody1 = oTransientBRep.Copy(oOcc1.Definition.SurfaceBodies(1))
Call oTransientBRep.Transform(oBody1, oOcc1.Transformation)
Dim oMatrix2 As Matrix
Set oMatrix2 = oOcc2.Transformation
oMatrix2.Invert
Call oTransientBRep.Transform(oBody1, oMatrix2)
Call oPartDef.Features.NonParametricBaseFeatures.Add(oBody1)
End Sub
Finaly I got a WorkSurface in 1st part. But I would like to have Solid2 not a surface. How I can convert that Surface to Solid. After it I can apply CombineFeature to Join them to one solid. If this feature is to be associative it would be very nice.
I tried implement KnitFeature for converting Surface to Solid, but I don't be success.
Might be you have another suggestion?
Best regards,
Saulius
