Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
How can I resize a drawing from format DIN A1 to DIN A3, including all views?
0 REPLIES 0
Message 1 of 1
julian.toll
126 Views, 0 Replies
I need to write a Powershell script which changes the size of a drawing from A1 to A3.
This is my original test drawing, (in this case sheetsize C):
With these lines I change the sheet size, but the Views remain unaffected:
$doc.ActiveSheet.Size = [Inventor.DrawingSheetSizeEnum]::kA3DrawingSheetSize
$doc.ActiveSheet.Orientation = [Inventor.PageOrientationTypeEnum]::kLandscapePageOrientation
The result is this:
Then I loop through all views and try to change their position and scale, in order to have them inside my new, smaller sheet:
for ($i = 1; $i -le $originalSheet.DrawingViews.Count; $i++) {
    try {
        $v = $originalSheet.DrawingViews.Item($i)
        $scale = ($v.Scale / $originalHeight * 28) # 28 = height of A3 Landscape
        $v.Scale = $scale
        $pos = $v.Position
        $xPos = $($v.Position.X / $originalWidth * 42) # 42 = width of A3 Landscape
        $yPos = $($v.Position.Y / $originalHeight * 28) # 28 = height of A3 Landscape
        [double[]]$coord = @($xPos,$yPos)
        $pos.PutPointData($coord)
        $v.Position = $pos
    catch {
        Write-Host "View Nr. $i : failed"
This is the result:
My sample drawing has 4 drawing views, two of them are projected views.
My problem is, that the projected views keep their distance from their "source-view", so they are outside of my sheet at the end
Does anyone know how I can move all views of any type to the right position?
Thanks in advance
0 REPLIES 0
Technology Administrators
