Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Hole /Thread notes edits
3 REPLIES 3
1184 Views, 3 Replies
How can I go about editing the text for a holethread note? I want to proceed the default text w/ the quantity note.
E.g.: 7/8 THRU
What I want: ?X 7/8 THRU
Any suggestions?
3 REPLIES 3
Vladimir.Ananyev
HoleThreadNote object supports two properties that could be useful:
FormattedHoleThreadNote – that gets and sets the fully formatted string that defines the contents of the dimension or note text.
FormattedQuantityNote – that gets and sets the fully formatted string that defines the contents of the dimension or note text.
Here is a sample:
Private Sub EditHoleThreadNote()
  Dim oDoc As DrawingDocument
  Set oDoc = ThisApplication.ActiveDocument
  Dim oSheet As Sheet
  Set oSheet = oDoc.ActiveSheet
  Dim oHoleThreadNotes As HoleThreadNotes
  Set oHoleThreadNotes = oSheet.DrawingNotes.HoleThreadNotes
  Dim oNote As HoleThreadNote
  Set oNote = oHoleThreadNotes.Item(1)
  Debug.Print oNote.FormattedHoleThreadNote
  Debug.Print oNote.FormattedQuantityNote
  'make changes
  oNote.FormattedQuantityNote = "<Quantity/> AAA"
End Sub
cheers,
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
in reply to: Vladimir.Ananyev
Vladimir,
Thank you for the reply, I must be doing something wrong. I tried your "EditHoleThreadNote" method and it yields no results. I tried inserting the "FormattedQuantityNote" at the front of the "FormattedHoleThreadNote" property and this blows up the entire note. The following is my code.
Public Overloads Sub AddThreadNote(ByVal _intent As GeometryIntent, ByVal _textLocation As Point2d)
                ' Create the hole/thread note.
                Dim _threadNote As HoleThreadNote
                _threadNote = Drawing.ActiveSheet.DrawingNotes.HoleThreadNotes.Add(_textLocation, _intent)
                _threadNote.QuantityDefinition = HoleNoteQuantityEnum.kNumberOfLikeHolesNormalToView
                ' I must reset the text origin because the initial location is (0,0) on the sheet.
                _threadNote.Text.Origin = _textLocation
            End Sub
If I'm doing something wrong, I can sure change.
Vladimir.Ananyev
Here is very simple VBA code that adds new thread note.
This sample works with the first selected hole in the drawing document.
Private Sub AddHoleThreadNote()
  Dim oTG As TransientGeometry
  Set oTG = ThisApplication.TransientGeometry
  Dim oSheet As Sheet
  Dim sset As SelectSet
  Set sset = oDoc.SelectSet
  If sset.Count = 0 Then
    Beep
    MsgBox ("Select some hole")
    Exit Sub
  Dim oCurve As DrawingCurve
  Set oCurve = sset.Item(1).Parent
  Dim oP As Point2d
  Set oP = oTG.CreatePoint2d(18, 25)
  Set oNote = oHoleThreadNotes.Add(oP, oCurve)
  oNote.QuantityDefinition = kNumberOfLikeHolesNormalToView
  'make some changes - I added <QuantityNote/>
  Dim St As String
  St = oNote.FormattedHoleThreadNote
  oNote.FormattedHoleThreadNote = "<QuantityNote/>" & St
  Beep
End Sub
Vladimir Ananyev
