Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Have the sheet name automatically generate in Title block
7 REPLIES 7
Message 1 of 8
brandon.lee97
734 Views, 7 Replies
brandon.lee97
I am trying to have my title block sheet name automatically populated once the sheet name has been set.
For example, the image i have attached shows the sheet names we type in,
but our current process requires us to type in the sheet name multiple times to appear both in the sidebar shown as well as the title block.
I am wondering if there is a way to make the title block auto-populate once the sheet name has been filled out in the sidebar.
7 REPLIES 7
Message 2 of 8
JelteDeJong
in reply to: brandon.lee97
JelteDeJong
you can try this.
Dim doc As DrawingDocument = ThisDoc.Document
Dim sheet As Sheet = doc.ActiveSheet
Dim titleBlock As TitleBlock = sheet.TitleBlock
Dim textBox As Inventor.TextBox = titleBlock.Definition.Sketch.TextBoxes.
        Cast(Of Inventor.TextBox).
        Where(Function(tb) tb.FormattedText.Contains("<Prompt")).
        Where(Function(tb) tb.FormattedText.Contains("SHEET DESCRIPTION")).
        FirstOrDefault()
If (textBox Is Nothing) Then Throw New Exception("Promted entry not found.")
titleBlock.SetPromptResultText(textBox, sheet.Name)
Jelte de Jong
Blog: hjalte.nl - github.com
you can try this.
        FirstOrDefault()
Jelte de Jong
Message 3 of 8
brandon.lee97
in reply to: JelteDeJong
brandon.lee97
Is there a way to update the code to remove the :1, :2 at the end
Message 4 of 8
JelteDeJong
JelteDeJong
here is an updated rule:
        FirstOrDefault()
Dim sheetDescription = sheet.Name
Dim puntPlace = InStr(sheetDescription, ":") - 1
sheetDescription = sheetDescription.Substring(0, puntPlace)
titleBlock.SetPromptResultText(textBox, sheetDescription)
Jelte de Jong
        FirstOrDefault()
Jelte de Jong
Message 5 of 8
brandon.lee97
brandon.lee97
Thank you for the help on this, one last thing, the code has to be run on each sheet. Is there a way to have to automatically run on each sheet in the drawing.
Message 6 of 8
JelteDeJong
JelteDeJong
try this:
For Each sheet As Sheet In doc.Sheets
    Dim titleBlock As TitleBlock = Sheet.TitleBlock
	    FirstOrDefault()
		MsgBox("Promted entry not found on sheet: " & Sheet.Name)
		continue for
	End If
    Dim sheetDescription = Sheet.Name
Next
Jelte de Jong
try this:
	    FirstOrDefault()
		continue for
	End If
Next
Jelte de Jong
Message 7 of 8
brandon.lee97
brandon.lee97
Instead of having the code reference a prompted entry. How would you adjust this to referencing iproperty vaule "SHEET DESCRIPTION"
Message 8 of 8
j.oudalstoel
j.oudalstoel
JelteDeJong
Just wanted to say thank you for providing this code. It solved an issue I was having with getting my title block to reflect the sheet name.
JelteDeJong
