Grip Snap
Grip Snap
GeorgK
Advisor Advisor
Grip Snap
GeorgK
Hello together,
is there any possibility to use the grip snap in VBA or iLogic to move a part along the axis?
Dim oControlDef As ControlDefinition
oControlDef = m_invApp.CommandManager.ControlDefinitions.Item("AppGripSnapCmd")
oControlDef.Execute()
Thank you
Georg
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi @GeorgK,
Unfortunately, Inventor API does not support API for "Grid snap".
"Grid snap" command can be called using "Control Definitions" API. But other inputs like selection of axis, type of drag and keying input (Distance).
Suggest this wish list at idea station using following link.
https://forums.autodesk.com/t5/inventor-ideas/idb-p/v1232/tab/most-recent
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
