Getting Camera Vector as values from current Assembly / Part View
NachoShaw
Advisor Advisor
NachoShaw
Hi
Is there a method of getting the Camera vector values from a current view in an Assembly or Part? Basically, I need to be able to rotate to the desired view, click a button and get the camera position so that I can save it and reload it at a later date. Its for image exports from specific directions
Cheers
Nacho
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
asiteur
I suppose you check this topic first:
http://forums.autodesk.com/t5/inventor-customization/move-camera-to-coord-on-drawing/m-p/6785079#M69...
Let me know if you need more support on the topic.
Best,
Alexander
Alexander Siteur
Project Engineer at MARIN | NL
LinkedIn
