Getting an error on auto arrange dimension code
2 REPLIES 2
bmerton
453 Views, 2 Replies
I am getting the following error when running this code from this post:  http://forums.autodesk.com/t5/inventor-general-discussion/ilogic-drawing-dimension-alignment-for-par...
It is saying  " 'Inventorapp' is not declared. It may be inaccessible due to its protection level."
Can anyone help?  Am a complete novice at VB...
 Dim doc As Inventor.DrawingDocument
        doc = inventorApp.ActiveDocument
        Dim ActiveSheet As Inventor.Sheet
        ActiveSheet = doc.ActiveSheet
        Dim dimensions As Inventor.ObjectCollection
        dimensions = inventorApp.TransientObjects.CreateObjectCollection
        Dim drawDim As Inventor.DrawingDimension
        For Each drawDim In ActiveSheet.DrawingDimensions
            If Not TypeOf drawDim Is Inventor.OrdinateDimensionSet _
            And Not TypeOf drawDim Is Inventor.BaselineDimensionSet _
            And Not TypeOf drawDim Is Inventor.ChainDimensionSet Then
                Call dimensions.Add(drawDim)
            End If
        Next
        Call ActiveSheet.DrawingDimensions.Arrange(dimensions)
2 REPLIES 2
salariua
in reply to: bmerton
Try
        doc = ThisApplication.ActiveDocument
        dimensions = ThisApplication.TransientObjects.CreateObjectCollection
            End If
        Next
Adrian S.
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
Did you find this reply helpful ?
If so please use the Accepted Solutions or Like button - Thank you!
in reply to: salariua
Their is an error on line 6.... End of Statement Expected.
Technology Administrators
