Hello.
I have a drawing with many different single parts on. I want to get the overall dimensions (height and width) automatically on all base views.
There is a rule written by "Jelte de Jong" which generates the overall dimensions (height and width) on a view that you as a user have to pick. (http://www.hjalte.nl/37-auto-overall-dimension)
I wanted my rule to iterate to all views and generate the overall dimensions.
But I cannot get the rule running. I get an error message "Object reference not set to an instance of an object."
Can anyone please help me?
Public Class ThisRule
' This code was inspired and uses much of a code by Jelte de Jong
Private _doc As DrawingDocument
Private _sheet As Sheet
Private _view As DrawingView
Private _intents As List(Of GeometryIntent) = New List(Of GeometryIntent)()
Sub main
' Check a document is open
If ThisApplication.Documents.VisibleDocuments.Count = 0 Then
MessageBox.Show("A Drawing Document needs to be open")
Exit Sub
End If
' Check active document
If ThisApplication.ActiveDocumentType <> Inventor.DocumentTypeEnum.kDrawingDocumentObject Then
Exit Sub
End If
' Get the active document
'Dim oDoc As Inventor.DrawingDocument = ThisApplication.ActiveDocument
_doc = ThisDoc.Document
' Iterate through all sheets
For Each _sheet As Inventor.Sheet In _doc.Sheets
' Iterate through all views
For Each _view As Inventor.DrawingView In _sheet.DrawingViews
' Check view is a base view, skip if not
If _view.ViewType <> Inventor.DrawingViewTypeEnum.kStandardDrawingViewType Then Continue For
CreateIntentList()
createHorizontalOuterDimension()
createVerticalOuterDimension()
Next ' Next view
Next ' Next sheet
End Sub
'Public Class ThisRule
' ' This code was written by Jelte de Jong
' ' and published on www.hjalte.nl
' Private _doc As DrawingDocument
' Private _sheet As Sheet
' Private _view As DrawingView
' Private _intents As List(Of GeometryIntent) = New List(Of GeometryIntent)()
' Sub Main()
' _doc = ThisDoc.Document
' _sheet = _doc.ActiveSheet
' _view = ThisApplication.CommandManager.Pick(
' SelectionFilterEnum.kDrawingViewFilter,
' "Select a drawing view")
' CreateIntentList()
' createHorizontalOuterDimension()
' createVerticalOuterDimension()
' End Sub
Private Sub createHorizontalOuterDimension()
Dim orderedIntents = _intents.OrderByDescending(Function(s) s.PointOnSheet.X)
Dim pointLeft = orderedIntents.First
Dim pointRight = orderedIntents.Last
Dim textX = pointLeft.PointOnSheet.X +
(pointRight.PointOnSheet.X - pointLeft.PointOnSheet.X) / 2
Dim textY = _view.Position.Y - _view.Height / 2 - 2
Dim pointText = ThisApplication.TransientGeometry.CreatePoint2d(textX, textY)
_sheet.DrawingDimensions.GeneralDimensions.AddLinear(
pointText, pointLeft, pointRight, DimensionTypeEnum.kHorizontalDimensionType)
End Sub
Private Sub createVerticalOuterDimension()
Dim orderedIntents = _intents.OrderByDescending(Function(s) s.PointOnSheet.Y)
Dim pointLeft = orderedIntents.Last
Dim pointRight = orderedIntents.First
Dim textY = pointLeft.PointOnSheet.Y +
(pointRight.PointOnSheet.Y - pointLeft.PointOnSheet.Y) / 2
Dim textX = _view.Position.X + _view.Width / 2 + 2
pointText, pointLeft, pointRight, DimensionTypeEnum.kVerticalDimensionType)
End Sub
Private Sub addIntent(Geometry As DrawingCurve, IntentPlace As Object, onLineCheck As Boolean)
Dim intent As GeometryIntent = _sheet.CreateGeometryIntent(Geometry, IntentPlace)
If intent.PointOnSheet Is Nothing Then Return
If onLineCheck Then
If (IntentIsOnCurve(intent)) Then
_intents.Add(intent)
End If
Else
End If
End Sub
Private Function IntentIsOnCurve(intent As GeometryIntent) As Boolean
Dim Geometry As DrawingCurve = intent.Geometry
Dim sp = intent.PointOnSheet
Dim pts(1) As Double
Dim gp() As Double = {}
Dim md() As Double = {}
Dim pm() As Double = {}
Dim st() As SolutionNatureEnum = {}
pts(0) = sp.X
pts(1) = sp.Y
Try
Geometry.Evaluator2D.GetParamAtPoint(pts, gp, md, pm, st)
Catch ex As Exception
Return False
End Try
Return True
End Function
Private Sub CreateIntentList()
For Each oDrawingCurve As DrawingCurve In _view.DrawingCurves
Select Case oDrawingCurve.ProjectedCurveType
Case _
Curve2dTypeEnum.kCircleCurve2d,
Curve2dTypeEnum.kCircularArcCurve2d,
Curve2dTypeEnum.kEllipseFullCurve2d,
Curve2dTypeEnum.kEllipticalArcCurve2d
addIntent(oDrawingCurve, PointIntentEnum.kCircularTopPointIntent, True)
addIntent(oDrawingCurve, PointIntentEnum.kCircularBottomPointIntent, True)
addIntent(oDrawingCurve, PointIntentEnum.kCircularLeftPointIntent, True)
addIntent(oDrawingCurve, PointIntentEnum.kCircularRightPointIntent, True)
addIntent(oDrawingCurve, PointIntentEnum.kEndPointIntent, False)
addIntent(oDrawingCurve, PointIntentEnum.kStartPointIntent, False)
Case _
Curve2dTypeEnum.kLineCurve2d,
Curve2dTypeEnum.kLineSegmentCurve2d
Case _
Curve2dTypeEnum.kPolylineCurve2d,
Curve2dTypeEnum.kBSplineCurve2d,
Curve2dTypeEnum.kUnknownCurve2d
' Unhandled curves types
Case Else
End Select
Next
End Sub
End Class
Solved by JelteDeJong. Go to Solution.
You can try it like this:
Sub Main()
For Each sheet As Sheet In _doc.Sheets
For Each view As DrawingView In Sheet.DrawingViews
If (view.ViewType <> DrawingViewTypeEnum.kStandardDrawingViewType) Then Continue For
_sheet = Sheet
_view = View
CreateIntentList()
Next
Next
End Sub
Dim textY = _view.Position.Y + _view.Height / 2 + 2
End Sub
Dim textX = _view.Position.X - _view.Width / 2 - 2
End Sub
If onLineCheck Then
End If
Else
End If
End Sub
pts(0) = sp.X
pts(1) = sp.Y
Try
Return False
End Try
Return True
End Function
Case _
Case _
Case _
Case Else
End Select
Next
End Sub
' Copyright 2021
' This code was written by Jelte de Jong, and published on www.hjalte.nl
' Permission Is hereby granted, free of charge, to any person obtaining a copy of this
' software And associated documentation files (the "Software"), to deal in the Software
' without restriction, including without limitation the rights to use, copy, modify, merge,
' publish, distribute, sublicense, And/Or sell copies of the Software, And to permit persons
' to whom the Software Is furnished to do so, subject to the following conditions:
' The above copyright notice And this permission notice shall be included In all copies Or
' substantial portions Of the Software.
' THE SOFTWARE Is PROVIDED "AS IS", WITHOUT WARRANTY Of ANY KIND, EXPRESS Or IMPLIED,
' INCLUDING BUT Not LIMITED To THE WARRANTIES Of MERCHANTABILITY, FITNESS For A PARTICULAR
' PURPOSE And NONINFRINGEMENT. In NO Event SHALL THE AUTHORS Or COPYRIGHT HOLDERS BE LIABLE
' For ANY CLAIM, DAMAGES Or OTHER LIABILITY, WHETHER In AN ACTION Of CONTRACT, TORT Or
' OTHERWISE, ARISING FROM, OUT Of Or In CONNECTION With THE SOFTWARE Or THE USE Or OTHER
' DEALINGS In THE SOFTWARE.
End Class
Jelte de Jong
Blog: hjalte.nl - github.com
Hi Jelte,
thank you for the answer.
Unfortunately the code is not working well.
The code generates the overall dimensions for the first view, but then it stops and gives an error message.
"The parameter is incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))"
So it just generates the overall dimensions on the first view, but when it wants to continue on the next view there comes an error.
Maybe some variables have to be reset but I cannot figure it out.
You are right, I did test the code only on a drawing with 1 view.... The variable "_intents" needs a reset for each view. try it like this:
Sub Main()
If (View.ViewType <> DrawingViewTypeEnum.kStandardDrawingViewType) Then Continue For
_intents = New List(Of GeometryIntent)()
_sheet = Sheet
_view = View
CreateIntentList()
Next
Next
End Sub
End Sub
End Sub
If onLineCheck Then
End If
Else
End If
End Sub
pts(0) = sp.X
pts(1) = sp.Y
Try
Return False
End Try
Return True
End Function
Case _
Case _
Case _
Case Else
End Select
Next
End Sub
' Copyright 2021
End Class
Jelte de Jong
