Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Get lenght of a chamfer
3 REPLIES 3
frank_schalla
441 Views, 3 Replies
Hmmm i dont find a way to get the lenght of a chamfer (selected edge) over the API.
Anyone has a idea ??
3 REPLIES 3
JelteDeJong
in reply to: frank_schalla
try this iLogic code:
Dim f As PartFeature = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFeatureFilter, "Select champfer")
If (TypeOf f Is CornerChamferFeature) Then ' for sheetmetal parts
	MsgBox(f.Definition.ChamferDefinition.Distance.Value * 10)
Else If (TypeOf f Is ChamferFeature) Then ' for parts
	MsgBox(f.Definition.Distance.Value * 10)
Else
	MsgBox("None champfer selected")
this does not work if the champfer option 2 distaces is chosen. in that case you could use:
  • f.Definition.DistanceOne.Value
  • f.Definition.DistanceTwo.Value
and calculate the distance your self.
Jelte de Jong
Blog: hjalte.nl - github.com
JhoelForshav
in reply to: JelteDeJong
I think what @frank_schalla is looking for is the length of the chamfered edge, Not the length parameter of the chamfer feature...
If so, maybe something like this should do the trick?
Sub Main
Dim oDoc As PartDocument = ThisDoc.Document
Dim oDef As PartComponentDefinition = oDoc.ComponentDefinition
Dim oChamfs As ChamferFeatures = oDef.Features.ChamferFeatures
Dim oChamf As ChamferFeature = oChamfs.Item(1)
oChamf.SetEndOfPart(True)
Dim totLength As Double = 0
For Each oEdge As Edge In oChamf.Definition.ChamferedEdges
	totLength += EdgeLength(oEdge)
Next
oChamf.SetEndOfPart(False)
MsgBox(totLength)
End Sub
Function EdgeLength(ByRef oEdge As Edge) As Double
    Dim curveEval As CurveEvaluator
     curveEval = oEdge.Evaluator
    Dim minParam As Double
    Dim maxParam As Double
    Call curveEval.GetParamExtents(minParam, maxParam)
    Dim curveLength As Double
    Call curveEval.GetLengthAtParam(minParam, maxParam, curveLength)
    EdgeLength = curveLength * 10
End Function
 For this example i simply took the chamferfeature item 1 in the model. But you can of course use it on a selected chamfer feature as well 🙂
Hello Jhoel Forshav
thank's you both and yes you are right.
The chamfer values was easy but based on you idea also the edges now we can grab
Thank You 🙂
