Get Fusion 360/desktop connector share link
2 REPLIES 2
william
477 Views, 2 Replies
Hello Everyone
I have a rule that will export a PDF (for an idw), or a dwf (for an ipt or iam) to a folder in my Fusion 360 desktop connector.
What I would like to be able to do, is access the file just created and copy the share link to my clipboard.
Any ideas how I could accomplish the attached?
It is only a couple of mouse clicks manually, I am hoping I can convert this to code somehow.
Labels (4)
2 REPLIES 2
william
in reply to: william
Ok, I have managed to do most of it.
See below example for publishing a PDF to Fusion Teams from Inventor and then opening the link online. So you can then set the shared link options.
Step One: Publish Rule, export from idw to F360 drive project and folder.
Make sure you have a txt file called "F360_Filepath.txt" saved in "C:\Scripts\"
'Rev 0 - 201029 - WI - Initial issue
'Check it is an .idw (see value for kDrawingDocumentObject in the API reference)
If ThisApplication.ActiveDocumentType <> 12292 Then
    MessageBox.Show("This is not a drawing. This rule can only be run in an .idw environment" & vbNewLine & "The rule will exit...", "Error Handling",MessageBoxButtons.OK,MessageBoxIcon.Error)
    Return
End If
' Check that this file has been saved and actually exists on disk
If String.IsNullOrEmpty(ThisDoc.Path) Then
    MessageBox.Show("This file has not yet been saved and doesn't exist on disk!" & vbLf & "Please save it first","Error Handling",MessageBoxButtons.OK,MessageBoxIcon.Error)
	Return
End If
Dim strUserProfile As String = System.Environment.GetFolderPath(System.Environment.SpecialFolder.UserProfile)
'MessageBox.Show(strUserProfile, "strUserProfile")
ExportPath = strUserProfile & "\Fusion\HARROWS\CAD OUTPUT\"
'MessageBox.Show(ExportPath, "ExportPath")
'Check that a save directory was found
If Not Directory.Exists(ExportPath) Then
	MessageBox.Show("There was an error finding the folder save location" & vbNewLine & "The rule will exit...", "Error Handling", MessageBoxButtons.OK, MessageBoxIcon.Error)
End If
Try
	drawingmodel = ThisDrawing.ModelDocument
	'MessageBox.Show(drawingmodel.FullDocumentName, "drawingmodel")
	oFileName = drawingmodel.PropertySets("Design Tracking Properties").Item("Stock Number").Value
		If oFileName = "" Then
		    MessageBox.Show("There is no value in the stock number." & vbLf & "Please complete the metadata first","Error Handling",MessageBoxButtons.OK,MessageBoxIcon.Error)
			Return
		End If
	ExportFilename = "SAL_" & oFileName & ".pdf"
	oWrite = System.IO.File.CreateText("C:\Scripts\F360_Filepath.txt")
	oWrite.WriteLine(ExportFilename)
	oWrite.Close()
Catch
    MessageBox.Show("There is no model document in the drawing." & vbLf & "Please create a drawing view first","Error Handling",MessageBoxButtons.OK,MessageBoxIcon.Error)
	Return
End Try
'Get the PDF export application
oPDFAddIn = ThisApplication.ApplicationAddIns.ItemById _
("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
oDocument = ThisApplication.ActiveDocument
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
'set PDF Options
If oPDFAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then
oOptions.Value("All_Color_AS_Black") = 1
oOptions.Value("Remove_Line_Weights") = 1
oOptions.Value("Vector_Resolution") = 400
oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets
End If
'Set the PDF target file name
oDataMedium.FileName = ExportPath & ExportFilename
MessageBox.Show(oDataMedium.FileName, "Filename")
Try
	'Publish document
	oPDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
Catch
	MessageBox.Show("Error writing out PDF", "Error Handling",MessageBoxButtons.OK,MessageBoxIcon.Error)
End Try
Q = MessageBox.Show("Do you want to open the link?", "F360 Publish", MessageBoxButtons.YesNo,MessageBoxIcon.Exclamation)
	If Q = vbYes Then
		R = MessageBox.Show("Has Autodesk Desktop Connector Finished processing the created file? If not wait until it has before proceeding", "Autodesk Desktop Connector Status", MessageBoxButtons.OKCancel,MessageBoxIcon.Exclamation)
			If R = vbOK Then
				ThisDoc.Launch(“C:\Scripts\F360_OpenLink.vbs”)
			End If
	End If
Step Two: Create a VB script called F360_OpenLink.vbs and save it in the location specified above. This was "C:\Scripts\" in my instance
'Some assumptions are made:
'You have a text file in the C drive with the location of the cad file stored as a string
Dim WshShell
Set WshShell = CreateObject("WScript.Shell")
Dim fso
Set fso = CreateObject("Scripting.FileSystemObject")
Dim file
Set file = fso.OpenTextFile("C:\Scripts\F360_Filepath.txt",1,-2)
Dim targetfilepath
targetfilepath = file.ReadAll
Call WshShell.Run("explorer.exe /select," & targetfilepath, 1, true)
WScript.Sleep 5000
WshShell.SendKeys "+{F10}"
WshShell.SendKeys "{DOWN}"
WshShell.SendKeys "{ENTER}"
WScript.Sleep 3000
Dim sh,w
myfolder = "C:\Users\william.HARROWS\Fusion\HARROWS\CAD OUTPUT"
Set sh = CreateObject("shell.application")
For Each w In sh.Windows
    If w.document.folder.self.Path = myfolder Then w.Quit
Next
This should open the folder, select the file you have just exported, activate the context menu with SHIFT + F10 (Sendkeys), arrow key down to the "View Online" option and ENTER to activate.
The remainder of the code is not always neccessary, but it just closes the opened folder. Our F360 project structure is very simple, and all exported files go to one location, so may need customising depending how yours is set up.
IMO this was simpler than trying to do this with Forge and Javascript programming. It may be of some use to someone else.
william
Correction.
Was
Should be
oWrite.WriteLine(ExportPath &ExportFilename)
Technology Administrators
