Is there a way to find the drawing curves (in my case 2 lines for an angular dim) of a dimension?
I had a quick look and can't seem to find a way to retrieve the entities a dimension is attached to from the "GeneralDimension" object.
Any pointers?
Cheers
Solved by Raider_71. Go to Solution.
Hi @Raider_71
Without looking, I think it will be similar to an example I just posted working with balloons, see this link:
https://forums.autodesk.com/t5/inventor-programming-ilogic/open-drawing-from-balloon/td-p/12760438
I hope this helps.
Curtis
Hi @Raider_71. This can be a complicated subject to describe. First of all, we have the DrawingDimension, which is the base type of all dimensions on a drawing, no matter what type or shape they are. Then there are the other, more specific types of dimensions that are 'derived' from that base type, and one of those is the GeneralDimension. Then that type also has some other even more specific dimension types that are 'derived' from that, and one of those is the LinearGeneralDimension (as an example, for discussion). Each level deeper you get in these 'types', there are more properties and/or methods (Subs & Functions) available for them, for the more specific type they represent. Well, at the LinearGeneralDimension level, we now have some properties that we can use towards your goal. (But different types may have different properties.) Some 'Links' to the online help documentation for some of those properties for this type are listed below:
LinearGeneralDimension.IntentOne
LinearGeneralDimension.IntentTwo
LinearGeneralDimension.IntentThree
Those last 3 give us a GeometryIntent object, as their value. This is like an object that defines the 'connection' between the dimension and something it is supposed to be attached to. We can 'sometimes' use this object, by inspecting its properties further, to find out what it is attached to (but not always). If the GeometryIntent.IntentType property's value is 'kGeometryIntent' (a variation of the IntentTypeEnum), then we will be able to get a value from its GeometryIntent.Geometry property. The default type of value we get from that is simply 'Object', because it can be many different types of objects. However, sometimes it is a DrawingCurve object (a single piece of 2D geometry on the sheet, within a DrawingView). If that is what you wanted to find, then were done, but if not, then you probably want to know what part of the actual model (in 3D model space) the DrawingCurve is associated with...and if so, read on.
If we get a DrawingCurve, and want to know what it is associated with in 'the model', then we can use its DrawingCurve.ModelGeometry property. Another one that just returns an 'Object', because it could be many different types of objects. Then more code may be needed to dig even deeper into identifying what type of object it is, and once we know that, we can extract further information from it.
Whew...😅
Wesley Crihfield
(Not an Autodesk Employee)
Hi @WCrihfield ,
Thanks for your detailed explanation! It pointed me in the right direction. I was not able to get an "AngularGeneralDimensions" collection object under "GeneralDimensions" but I managed to check the type of each "GeneralDimension" inside "GeneralDimensions" and then if it was type of "kAngularGeneralDimensionObject" then I converted the type to "AngularGeneralDimension" and worked from there. Below is my code just for reference. Feel free to tell me if there is a better way to do it.
Dim GenDims As GeneralDimensions = oSheet.DrawingDimensions.GeneralDimensions
Dim oAngDim As AngularGeneralDimension
For Each oDim As GeneralDimension In GenDims
If oDim.Attached Then
If oDim.Type = ObjectTypeEnum.kAngularGeneralDimensionObject Then
oAngDim = CType(oDim, AngularGeneralDimension)
If oAngDim.IntentThree Is Nothing Then
MessageBox.Show("yes")
End If
End If
End If
Next
