Hello
I have an assembly containing subassemblies and parts. If i have an part edge, is there a way to get all edgeproxies representing this edge in context of the main assembly? I can circle through all edgeproxies in the assembly context and check if the native object is my edge, but this is very slow.
Solved by JhoelForshav. Go to Solution.
Hi @Ralf_Krieg
Something like this maybe? 🙂
Sub Main 'Get a nativeobject for an edge, I dont know where you're getting the edge object from. Dim oEdge As Edge = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartEdgeFilter, "Pick edge.").NativeObject Dim oPart As PartDocument = oEdge.Parent.ComponentDefinition.Document Dim oAsm As AssemblyDocument = ThisDoc.Document Dim oSelSet As SelectSet = oAsm.SelectSet Dim oEdgeCol As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection For Each oOcc As ComponentOccurrence In oAsm.ComponentDefinition.Occurrences.AllReferencedOccurrences(oPart) Dim oEdgeProx As EdgeProxy = CreateEdgeProxy(oOcc.OccurrencePath, oEdge) oEdgeCol.Add(oEdgeProx) Next oSelSet.SelectMultiple(oEdgeCol) End Sub Function CreateEdgeProxy(oOccList As ComponentOccurrencesEnumerator, oEdge As Edge) As Object Dim oProx As Object For i = oOccList.Count To 1 Step -1 If i = oOccList.Count Call oOccList(i).CreateGeometryProxy(oEdge, oProx) Else Call oOccList(i).CreateGeometryProxy(oProx, oProx) End If Next Return oProx End Function
Jhoel Forshav Download my free Inventor Addin - Hole Projector
LinkedIn | Ideas | Contributions | Blog posts | Website
I just realized you don't have to send the proxy up through each occurrence of the occurrencepath.
This will do.
'Get a nativeobject for an edge. Dim oEdge As Edge = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartEdgeFilter, "Pick edge.").NativeObject 'Get the part document the edge belongs to. Dim oPart As PartDocument = oEdge.Parent.ComponentDefinition.Document 'Get the top level assembly Dim oAsm As AssemblyDocument = ThisDoc.Document 'Get the Assemblys select set. Dim oSelSet As SelectSet = oAsm.SelectSet 'Create an ObjectCollection to add all edge proxies to. Dim oEdgeCol As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection 'Loop through all occurrences of the part. For Each oOcc As ComponentOccurrence In oAsm.ComponentDefinition.Occurrences.AllReferencedOccurrences(oPart) 'Create a proxy for the edge Dim oEdgeProx As EdgeProxy oOcc.CreateGeometryProxy(oEdge, oEdgeProx) 'Add proxy to the object collection oEdgeCol.Add(oEdgeProx) Next 'Select everything in the object collection oSelSet.SelectMultiple(oEdgeCol)
Hello
Thank you. I have integrated your second code. Works perfect. 👍
