Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Get active sheet revision
5 REPLIES 5
580 Views, 5 Replies
How can you retreive the active sheets revision? I can't find any reference to it anywhere in the API documentation.
5 REPLIES 5
I would imagine that it is set in the driving model file iProperties.
Out of the box I think it is called "Revision Number."
Not the iProperty, the revision property associated with each individual sheet.
Right click on the sheet in the browser, select properties... that revision property.
Mike.Wohletz
Mike.Wohletz
Will it work for you to pull it from the revision table?
    Public Function GetSheetRevision() As String
        Dim Revision As Integer = Nothing
        Dim oDrawDoc As DrawingDocument = oApp.ActiveDocument
        Dim oRevisionTable As RevisionTable = oDrawDoc.ActiveSheet.RevisionTables.Item(1)
        For Each oRevRow As RevisionTableRow In oRevisionTable.RevisionTableRows
            Try
                ' we will deal with it as ASCII characters so it will handle either numbers
                ' or letters, but not both.
                'I have guessed that the secont column holds the revision number
                If System.Text.Encoding.ASCII.GetBytes(oRevRow.Item(2).Text)(0) > Revision Then
                    Revision = System.Text.Encoding.ASCII.GetBytes(oRevRow.Item(2).Text)(0)
            Catch ex As Exception
            End Try
        Next
        Return Chr(Revision)
    End Function
            Try
            End Try
        Next
    End Function
Unfortunatly, we don't use the tables, just the rev property.
Same Probleme .... Have you a solution ?
I don't use RevisionTables, just a text
